Results 1 to 5 of 5
Thread: Engine Oil XL600
    Burge is offline Junior Member
    Apr 2009
    Lincoln
    Engine Oil XL600
    Hi,
    Which engine oil should I use for my 1983 XL600RD the haynes manual say's 10w 40 but some people use 20w50. What do you reckon?
    Thanks Burge.
    Apr 2007
    East Anglia-ish
    Re: Engine Oil XL600
    Well 20w oil is stickier so it may prolong the life of bearings and so on but on an overhead cam it will not flow as quickly so the head may melt.
    I think that for riding in the UK and NW EU 10w40 is fine unless your engine is very tired/rattley when a higher weight may give it a little better protection, check for the addatives though as again its a ying yang thing. Potash will turn gungy but your valv's will love it and zinc sticks to metal so is like a microscopic thrust bearing.
    And remember if oil gets hotter than its designed for it becomes broken and is no longer oil,just black goo ......blah blah......
    I think that there is a chart some where which shows oil weights and the temp range it's good for. could be worth a google.
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    I used to use 20w 50 in an XL250 and it ruined the head, due to the oil not reaching the camshaft properly and it ate the head.
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    I've been using 10/40 in everything without probs.
    so far.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    Apr 2009
    Lincoln
    Great thanks guys 10w 40 it is!
  1. Xl600 Engine.
    By StumpyFingers in forum Transalp
    Last Post: 16-03-09, 01:19 AM
  2. Wanted: Xl600
    By stubbow in forum For Sale / Wanted
    Last Post: 15-03-09, 11:19 AM
  3. xl600 on ebay
    By micksylver in forum For Sale / Wanted
    Last Post: 20-08-08, 09:29 PM
  4. TA XL600 M reg
    By skyrise in forum For Sale / Wanted
    Last Post: 04-08-08, 09:27 AM
  5. xl600
    By Charlie in forum XL
    Last Post: 11-07-08, 12:43 PM
