Results 1 to 3 of 3
Thread: CG125E trail ?
    ballores Guest
    CG125E trail ?
    Hi bought a bike cheap other day has a loose vin plate says cg125e engine cg125e looks like a trail made road legal ie the rubber strapped lights no indicaters or indy switch bolt on chainguard etc needs rewiring i have the v5 just says honda motorbike 125cc what you guys think ie if i get a pull btw 82 reg wondered if they did that sort of thing could you legalize a trail bike then cheers Nick.
    Bill Badger's Avatar
    Bill Badger is offline Member
    May 2008
    Cannock, Staffordshire
    Re: CG125E trail ?
    What do you mean by 'legalise a trail bike'?
    Honda made trail bikes for road use since the late 1960s. I think your bike could be a home conversion, but it could be ok if it is since the CG125 has a pretty robust engine.
    ballores Guest
    Re: CG125E trail ?
    Hi Bill it does look like a home conversion the frame looks too big for a 125 the engine sits up tight at the front and there are two bracket from the frame supporting the bottom of the engine the frame id is a little loose and the log book doesn't have a model but frame id says cg125e just wondered about insurance for this one go ahead as a cg125e? your thought would be appreciated just wondered about the lagality of this one if i got a pull cheers Nick.
  1. End 2 End Road Trail
    By jasonbc in forum Ride Reports and Pictures
    Last Post: 30-03-09, 03:03 PM
  2. Big trail rides
    By zedtours in forum Meet Ups / Rideouts
    Last Post: 08-03-07, 03:15 AM
  3. where did the big trail bikes go?
    By icenian in forum Chatter
    Last Post: 21-02-07, 01:31 PM
  4. Big Trail Bike
    By haydnw in forum Africa Twin
    Last Post: 21-01-05, 07:31 PM
