Results 1 to 10 of 13
Thread: XL600r
    Kev W is offline Member
    Apr 2009
    Westbury, Wilts
    XL600r
    Been lurking for a while but have finally bought an XL600r something I've always fancied!
    It's a 1984 model in er 'well used' condition. Had it a couple of weeks now and have got it starting easily and reliably from cold and when hot without the aid of a hill. Have re-covered the seat and fitted indicators but still need to get rid of the ghastly and not very effective headlight unit just keeping an eye out for something a little more appropriate, do like the twin headlights from the LMF but where would they be available from? Also replacement side panels, are pattern parts available as I have so far been unable to locate any. Any help appreciated.
    Been out on Sailisbury plain and had great fun with it, okay a little heavy but appears to be more than capable for my needs and considerably lighter than my other bike. Look forward to seeing some of you out there over the summer.
    Kev
    First ride onto the plain on the XL
    My pair!
    Tiger 955i on one of the Plain tracks
    Andyxl is offline Junior Member
    Feb 2009
    Bridport
    Re: XL600r
    I like the XL600r Kev
    Look on the bright side, with summer coming you won,t be needing the headlight much anyway
    I would think ebay would find you a replacement headlight and suround panel, not sure if you could fit one from a xl350/250 at a push.
    Click here: Honda XL600 XL 600 RMG,LMF Headlight on eBay, also Honda, Motorcycle Parts, Motorcycle Parts Accessories, Cars, Pa
    Apr 2009
    Westbury, Wilts
    Re: XL600r
    [QUOTE=Andyxl;368794]I like the XL600r Kev
    Good point!
    By some miracle a breaker in Bristol advertised parts from an RM/LMF yesterday and I was able to get the twin headlamp unit and cowling for a sensible price With a couple of small mods to the existing brackets the headlamps are fitted and with a couple of new bulbs are working! Now in the process of tidying up the cowling. When finished I'll post a picture.
    Regards,
    Kev
    Feb 2009
    Bridport
    Re: XL600r
    Ive not had a XL600r before,but i remember my old XL500r had a nasty habit of sometimes just conking out just as i was about to pull away from junctions or traffic lights.
    There was nothing more embarrasing than pushing the bike to the side of the road in front of a que of cars, then kicking it over til swet dripped into your eyes before it would fire up again
    Be good to see some more pics of your bike
    Re: XL600r
    Quote Originally Posted by Andyxl View Post
    Happened all the time with the Armstrongs.
    Apr 2007
    East Anglia-ish
    Re: XL600r
    If the headlamps are the old bulb type then the Africa twin lamps are a direct replacement and obviously give you H4 bulb options......
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    Apr 2009
    Westbury, Wilts
    Re: XL600r
    Quote Originally Posted by meljordan View Post
    Thanks that's worth knowing, they are the old type and clearly not as 'bright' as the H4's but okay for now. Should I break a lamp I could replace it with the Africa twins.
    Have got the cowling stripped, sprayed and re-fitted tonight and well pleased with the result so will take a picture in day light and post it here.
    Apr 2009
    Westbury, Wilts
    Re: XL600r
    Twin headlamps fitted and working! Indicators fitted aswell...I can't get on with this sticking arms out thing. Kev
    Mar 2007
    Bridport Dorset
    Re: XL600r
    Quote Originally Posted by Kev W View Post
    i like that! looks good with twin lights on.
    ade's Avatar
    ade
    ade is offline TRF member
    Jul 2009
    Bromsgrove
    Re: XL600r
    which breaker was it?.i need a mph speedo
    a thread on advrider said there are going to be a full sets of repro plastics soon,some patterns have been made and work out for side panels around $68 plus post.
    DC plastics is the name of the company
  1. Advice on XL600R
    By Burge in forum XL
    Last Post: 14-10-09, 01:07 PM
  2. Bit Slow XL600R
    Last Post: 06-04-09, 12:54 PM
  3. XL600 LM wheel conversion to XL600R
    By rsstom in forum XL
    Last Post: 01-06-08, 03:19 PM
  4. XL600R
    By thumper in forum Dominator / FMX
    Last Post: 03-03-06, 12:41 PM
