Seized in engine bolt.
Has anyone else ever had the bottom engine to frame bolt seize up, and if so how have you worked it free?
Ive got the engine out now from a cb250rs by cutting one side of the bottom bracket, and wiggling it out sideways. But i,m still left with the bolt well seized into the engine casing ![]() I intend to take it to my mates garage and tip the engine on its side in his press, and push it out as you would a car wheel bearing. The head of the 14mm bolt rounded off after considerable pressure was used so i thought i would weld on a larger nut,thats when i discovered the bolt was cast, and the welder didn't like that much ![]() Why is it the simplist of job's always go pear shape on me !!! |
Re: Seized in engine bolt.
Heat is the best things for stuff that is seized,think i will warm it up first then introduce it to some pressure from the press
Ive got a golf ball size swelling on my hand at the moment, where i hit it with a BFHammer earlier !! |
Quote:
Hitting your hand with a hammer will not loosen or remove a seized bolt in your bike engine.
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE |
Quote:
It taught me French though,never new i could say so much |
Well thanks to a 11 quid propane burner and a new 4 lb sledge hammer, i got the stubborn bolt out today
Took a couple minutes of heating and half a dozen hit's with a decent wacker, but it started to budge and then came out quiete quickly. Never underestamate the power of heat
| Bookmarks |
| Tags |
| bolt, engine, seized |
| Thread Tools | |
| Display Modes | |
| Engine mounting bolt?????? | chalky4 | Transalp | 2 | 13-04-09 07:18 AM |
| Seized calliper - help please. | Grooverider | Bike Tech | 5 | 16-02-09 08:24 PM |
| Seized piston. | StumpyFingers | Transalp | 2 | 08-01-09 07:35 PM |
| seized! | Shayite | Transalp | 4 | 08-06-08 08:26 PM |
| siezed swingarm bolt and siver paint 4 my engine? | camnz | Africa Twin | 0 | 27-04-08 04:49 PM |
