Results 1 to 8 of 8
Thread: XL engine into an XLR frame
    Icon101 is offline Junior Member
    May 2009
    West Lothian Scotland
    Question XL engine into an XLR frame
    Hello to all,I'm new to the forum and my XLR125 so excuse me if I sound a bit daft!Can anyone help? My XLR 125 is a bit worse for wear and I have the chance of an XL 125 engine, a 2007 model, together with the exhaust and plastics.Now this would be an ideal scenario if i could swap the lot over!Can anybody tell me if any or all is possible? Cheers!
    Re: XL engine into an XLR frame
    Hello and welcome to the forum.
    The best way to tell would be by the engine numbers, it is possible that the mountings are in a different position which would mean NO it will not fit.
    But I am not too sure about this bike.
    May 2009
    Thanks for the quick response ,I guess that parts of the engine numbers will be the same if they fit?.If thats the case I'll need to find out both engine numbers.
    Mar 2007
    Bridport Dorset
    you may be lucky and it will slot right in where the old engine went. dont think Honda 125 engines are much different year by year.
    anything can be made to fit anything else with a grinder and a welder tho.
    that is the last resort of course
    hondaxrnut is offline Senior Member
    Oct 2008
    somerset
    these engines are identical in virtualy all respects on the outside, the problem may lie in the electrics and ignition.
    the mounting bolts are the same and in the same place, the xlr engine is just a better designed xl engine anyway.
    what is wrong with your engine?
    unless you can get the xl engine cheap, you may find that you need a different ignition, and some wiring chamges.
    good luck
    shaun
    May 2009
    Hi thanks for the reply.My engine has a burst Generator casing and a snapped stud in the exhaust cylinder head plus could do with some rings. I think I would be better fixing my own engine. The XLR is a better engine I hear. Thanks everybody who replied.
    mad mitch is offline Member
    Mar 2010
    stirling scotland
    Quote Originally Posted by Icon101 View Post
    Hi yes the engine is the same i have the xl manual here in my hand and have an xlr 125 honda the only difference is your one has a kick start even the electrics are the same hope that helps and welcome to the best bike forum ever
    Mar 2010
    stirling scotland
    hi if your going to do up your xl engine then ebay is the place for spare parts there is loads of bits and bobs around the exhaust stud will come out fine easy just dont drill it or grind it away
  1. XR engine to XL frame
    By HIFIMC in forum XL
    Last Post: 16-05-09, 08:07 AM
  2. Rd04 engine into rd03 frame
    By mudbogger in forum Africa Twin
    Last Post: 10-10-08, 02:36 PM
  3. AT Engine and Frame
    By edteamslr in forum For Sale / Wanted
    Last Post: 19-07-08, 09:33 AM
  4. engine /frame mumbers
    By 1965paulh in forum Africa Twin
    Last Post: 26-07-06, 01:17 PM
  5. rd04 engine in a rd07 frame ??
    Last Post: 03-03-06, 05:46 PM
