Results 1 to 10 of 11
Thread: Stickers for Xl600 LMF
    andreww5680 is offline Member
    May 2009
    Milton Keynes
    Hello Fellow Honda owners
    Do any of you know where i may be able to purchase some new decals as i am carrying out a restoration project. Also does anyone have any information on the red engine paint ie: what type is it, colour code etc
    Thanks in advance
    Andrew
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Re: Stickers for Xl600 LMF
    I think you'll have problems getting the paint,especially 20 odd years on. Some people use engine enamel i've heard of powder coating but never of any success. Mel jordan is the man to speak to he has just restored one and painted all the panels so he will have an idea of the codes he used.
    As for the engine i used to paint the blocks of my escorts and capris with 2pac and never had any problems and it stayed shiney.
    good luck
    Apr 2007
    East Anglia-ish
    Hi all for a full sticker set try here.
    Welcome to New Forest Signs Bespoke Printing Services
    and for any one offs try here
    Mirage Signs - Stickers
    Simples......
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    May 2009
    Milton Keynes
    Thank you Mel for the help with the stickers..
    I have seen your LMF - job well done !!!
    Love the dakar mods, very tastefull and not OTT.
    Do you know the RAL no of the engine paint ???
    What paint did you use?
    I have bits of mine being painted at the mo- everything black i can get done for free at work in powdercoat i have had the frame powder coated white and think the engine should be done in a heat resistant 2 pack-
    Any advice would be much appreciated
    Thanks in advance
    Andrew
    Apr 2007
    East Anglia-ish
    I keep meaning to actually read the label on the tin.....will have a look over the weekend if i get a chance......
    ADVERTISE HERE.
    Absynth eye drops
    May 2009
    Milton Keynes
    Thank you Mel
    much appreciated.
    I want to make sure the paint is good- esp if you want to use it, not just spend all its time wrapped in silk in a heated garage !!!
    What is to be gained from fitting an oil cooler (i have seen from your pics) obviously cooler oil = longer lasting engine. Does it really boost performance- surely it has sufficient cooling for itself without any mods ?
    Or did you uprate something ??
    Thanks again for your help.
    Apr 2007
    East Anglia-ish
    Well the xl has a habit of cracking its own head between the sparkplug and valve seats which lets the seats drop with the obvious result.the best way to avoid this or stop it getting to the point where the engine is fooked is to fit a cooler which helps keep a suprising amount of heat away from the head and an improved oil feed up to the head by using a flexi pipe with a bigger bore, or even drilling the banjo bolt out to improve the flow. Simple ideas which help keep a great bike in the dirt......
    ADVERTISE HERE.
    Absynth eye drops
    Apr 2007
    East Anglia-ish
    And some decent red engine paint from here
    RED ENGINE PAINT PNENR
    ADVERTISE HERE.
    Absynth eye drops
    May 2009
    Milton Keynes
    Thanks a million MEL
    Do you think i should get this aerosol as apposed to getting it painted in 2 pack ? I have it blasted ready for paint
    Obviously it would cost less to do it myself but i was prepared to have it sprayed. How good do you find this paint in terms of durability ?
    How many tins did you use ? Did you strip back to metal or did you paint over the old paint ?
    Thanks again MEL
    Apr 2007
    East Anglia-ish
    If you have it back to metel then 2pack and it's allways best to let the pro's do it though the spray paint is fine for touch up and general cover ups......
    ADVERTISE HERE.
    Absynth eye drops
  1. xl600 lmf
    By mid life crisis in forum XL
    Last Post: 03-06-09, 09:59 AM
  2. Wanted: Xl600
    By stubbow in forum For Sale / Wanted
    Last Post: 15-03-09, 11:19 AM
  3. XL600 lmf Carbs
    By daithejack in forum XL
    Last Post: 14-03-09, 11:00 AM
  4. TA XL600 M reg
    By skyrise in forum For Sale / Wanted
    Last Post: 04-08-08, 09:27 AM
  5. xl600
    By Charlie in forum XL
    Last Post: 11-07-08, 12:43 PM
