Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: XL600 OIL COOLER bodge/mod
    Apr 2007
    East Anglia-ish
    Re: XL600 OIL COOLER bodge/mod
    Hi Kirtek, i was looking for a valve block that i could bypass easily as i wanted to keep the whole thing as simple as possible and obviously robust.I agree with you that the f/mudguard is as good a place as any and am looking at one of these or similer.
    I need to be sure that it will work at the right temp range and that if it fails it fails in the fully open position. So i will keep you posted
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    That looks excellent. Do keep us posted.
    I can give you the drawings for the thermostat unit on my XL, if you're interested. It hasn't failed a single time in almost ten years of use.
  4. #13
    Apr 2007
    East Anglia-ish
    That would be good,if yours has been that reliable then it must be a good solution.
    ADVERTISE HERE.
    Absynth eye drops
  5. #14
    Krtek's Avatar
    Okay, I have uploaded the sketch and some other related pics to my gallery, so anyone who may want to can check them out. Here you go:
    XL thermostate - Honda Trail Bike Forums
  6. #15
    tractot4play is offline Member
    Jan 2009
    belfast
    Quote Originally Posted by meljordan View Post
    Hi buddy not sure why i get photos, will redo them and see......
    hi mel,can you tell me the name of the flexibles you used and where you got them.regards ian.
  7. #16
    coldo is offline Member
    Aug 2009
    scotland
    hi i cant see the pictures ,is there a link ,
  8. #17
    Apr 2007
    East Anglia-ish
    Hello all, I used Pirtek UK : Europe's Number One provider of fluid transfer solutions. Hose replacement, mobile hose replacement. for both the pipes and unions. The advantage being that they are van based so the feller could measure cut and fix ends on site.
    This obviously only works cheaply if you have a job that involves kit with hydrollic systems and so on but the feller who made my solution also works on other peoples kit.
    ADVERTISE HERE.
    Absynth eye drops
  9. #18
    Jan 2009
    belfast
    thanks for the link.its not what i would call a bodge looks like you put abit of thought into it.you certainly will not be worried about an oil leak.best of luck ..ian.
  1. Oh Bodge it!
    By moon in forum Ride Reports and Pictures
    Last Post: 04-05-09, 09:56 AM
  2. My first bodge.
    By Warthog in forum Bodgers Corner
    Last Post: 09-07-08, 08:45 PM
  3. Oil Cooler
    By Richard Ludwell in forum Dominator / FMX
    Last Post: 24-06-08, 08:14 PM
  4. Re Oil cooler
    Last Post: 24-01-08, 06:32 AM
  5. Oil Cooler on TA
    By Gromit3528 in forum Transalp
    Last Post: 05-09-07, 03:16 PM
