hi do you still have the rh side panel as im in need of one
hi there i have just got hold of a lmf from down your way and im looking for some bits for it ,can you help me ,eaven if you could give me a wee list it would be great ,also the email of the person who makes the tank decals , i bought my bike after looking at yours and drooling ,
I don't have any parts to sell but there is a chap on ebay breaking one at the moment
The chap we got are decals from can be contacted here orders@bikedecals.co.uk
Good luck with the bike they are great fun oh and remember to stick some pictures up
Danny
Is it finished yet?
Sorry guys split up with mrs etc etc has meant the project was put on hold for a few months - i will upload some more pics soon as it is coming on well... deffo still holding on to it !!
I promise to upload some more pics soon![]()
Strictly speaking to skim a head you should make up a jig that holds the head exactly parallel then put it on a surface grinder and grind off the minimum amount to take off all the high spots. The same should be done with the barell. Since i know a local engineering company they lent me some ground flat stock (flat steel plate approx 30mm thick with a surface ground face typically used for machine tooling etc) - as this is very flat i put some very light emery paper on the surface and put the head and barell face down then rotated them while holding the paper until you could see that the high spots had been removed.
This method has been used by a number of my associates on other motorbikes and could save a hefty machining bill !!
No there is no impact on engine timing - obviously you have to dismantle the engine and thus upon reassembly it needs to be re timed - this isnt really that much of a chore though. Obviously if you were to take a lot of material off the faces of the head and barell it would
a) increase the compression
b) if too much was taken off the vales and piston could collide
Right everyone enjoy your nap !!!!!
Here you go guys - current progress
I have done a little more work since this pic was taken
Sorry it has taken so long
Andy
