Results 1 to 10 of 13
Thread: xl600 crank bearings gone - repair/replace?
    krypton is offline Member
    Mar 2009
    essex
    Lot of movement top and bottom, can they be repair easily with new bearings/pins or whatever? I have an engineer to make parts if needed, but anyone done it before? Are spares bearings/pins available?
    Thanks for any advice, or does anyone have a known good crank spare?
    mad4it028 is offline Senior Member
    Aug 2009
    peterborough
    Re: xl600 crank bearings gone - repair/replace?
    ive a whole bottem end sat here compleat if your interested?
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    When that happened to mine I bought a new piston (it was about time to replace that anyway) and conrod from ProX and had the crankshaft rebuilt with those (and new bearingd of course). Also, the cylinder was honed to fit the new piston.
    Result... good as new.
    Mar 2009
    essex
    is it for the electric start model?
    Have you measured the play in the big end? 0.8mm lateral, 0.05mm radial play are the limits.
    Is the con rod included?
    Mar 2009
    essex
    How much for the con rod kit?
    Where did you get it from?
    How much for the piston kit?
    Aug 2009
    peterborough
    Quote Originally Posted by krytpon View Post
    the head and barrels are still attached so not measured anything
    Mar 2009
    essex
    not sure if I want to risk it, as it can't be guaranteed good. How much were you wanting for it? What part of the country are you in?
    Aug 2009
    peterborough
    £50 you can have whole engine apart from cam and rocker arms but as you rightly pointed out it is a chance as ive no idea to the condition inside the engine
    Mar 2009
    essex
    Good price, I'm still undecided as to what to do. I'm going to make a few calls to see if I can just get a price on the top and bottom end bearings. I know it means making some funky tools to get it all apart but at of swearing but I don't have the cash to go out and buy a piston and conrod kit.
    I've not even ridden the bike and its my first big bike after passing my test, not sure if I want to increase its performance!
    Aug 2009
    peterborough
  1. How to build your own Crank shaft
    By raymo in forum Chatter
    Last Post: 10-06-09, 11:21 AM
  2. XR 400 Crank / conrod
    By podgyduck in forum XR
    Last Post: 17-05-08, 09:26 AM
  3. XR 400 main crank bearings
    Last Post: 17-05-08, 09:20 AM
  4. Steering head bearings - how much to replace?
    By Slimjim in forum Transalp
    Last Post: 24-05-07, 10:55 PM
  5. Crank
    Last Post: 22-04-06, 12:36 AM
