Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Poor starting when hot
    ade's Avatar
    ade
    ade is offline TRF member
    Jul 2009
    Bromsgrove
    Re: Poor starting when hot
    I can now report that its getting easier to start due to getting the technique right,and a nicely adjusted auto de-comp cable,which took some fiddeling to get right,but can be a sod if you dont catch it right sometimes when warm,and it did help when the plug cap was screwed in properly.
    As im running in a new piston and rings it is definately getting better with use and pulls like a train......roll on summer
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Have you checked the float height. A high fuel level in the float chamber is a common cause of difficult starting when hot it was what cured the xr's difficult starting when it was hot only 1mm out as well made all the difference
  4. #13
    afk40's Avatar
    afk40 is offline Senior Member
    May 2006
    Near Glasgow Scotland
    Ade,, Ive had an xl600 before.. the kickstart one is known to be a bitch when its hot to start,, Id try an fit a starter to it,, my pal fitted one to his 600.. an it makes life easier... ye need to get it right , jist past top dead centre, an gie it a good kick,,, that kickin all the time knackers ye quick.......... agin i had a TT600 an that was the same.. when HOT it doesnt want to start......... sorry tae say,, i just bit the bullit an got maself something else.. the xl600`s are nice,, but if tey jist wont start when their hot.. whats the use............. the xl500R is the same,, but a bit easier ........ go fur an Xl600M
  5. #14
    Krtek's Avatar
    Krtek is offline They say I talk too much.
    Arnhem, the Netherlands
    Honestly mine isn't all that bad. I can always get it running even if it may take me a little while sometimes.
    Maybe I'm WonderWoman or something...
  6. #15
    ade's Avatar
    ade
    Jul 2009
    Bromsgrove
    I have thoughts of fitting electric start,due to
    the kickstart missed the ratchet and buggerd my knee up.
    Its mostly technique now as its getting easier to start,just got to show it whos boss.
    I will look into the float height with looking into up jetting for a richer mixture.
    I always wanted the LMF,maybe when im in a better position financially
  7. #16
    Krtek's Avatar
    It is indeed mostly technique.
    Here's what I do: press the manual decompressor, open the throttle all the way, give it a few kicks to flush the cylinder with air and dry off the spark plug if needed.
    Let go of the decompressor, use the kickstarter to find the compression, use decompressor to put it juuuuust a little further than that.
    Let the kickstarter come all the way up, open the throttle about a hair's width, and give one good, decent kick, all the way down.
    Usually does the trick. And I'm female, 60 kilos and fairly short. So it's not a matter of being strong or heavy.
  8. #17
    afk40's Avatar
    May 2006
    My technicque is I pull ma hand out ma pocket,,, get ma Thumb in an upright position an press firmly. tae it starts... whallla its got tae be easier than that kickin lark.. thats fur aul school.. this is 2010
  9. #18
    kikthebitch Guest
    are we talkin about your bike here or pocket rocket
  1. wet/poor running
    By joe 90 in forum XR
    Last Post: 28-06-09, 03:51 PM
  2. XLR poor starting and running
    By supermoto1962 in forum XR
    Last Post: 03-06-09, 09:04 PM
  3. The poor poor bike !!
    By cbrpaddy in forum Chatter
    Last Post: 08-05-09, 06:08 PM
  4. Poor AT
    By Tikka in forum Africa Twin
    Last Post: 25-06-05, 06:55 PM
