Results 1 to 3 of 3
Thread: standard sprocket sizes
    ade's Avatar
    ade
    ade is offline TRF member
    Jul 2009
    Bromsgrove
    can anyone tell me the sizes for standard gearing,as im finding im having to change down a lot in order for smooth riding as the engine seems to labour a lot.sprockets fitted are 15 front and 40 rear
    also im thinking of up jetting the carbs,what size is recommended
    Titch's Avatar
    Titch is offline Senior Member
    Feb 2009
    Oldham, Manchester
    Re: standard sprocket sizes
    I asked a simular question about changing the gearing of my sprokets, and was directed to this site Gearing Commander: Motorcycle Gear Ratio Calculator for Sprockets RPM Speed Chain It works by putting in your bike details at the top of the main page, and it gives you the standard sproket gearing and then allows you to change it using the custom bit.
    But if you want to find out your standard gearing then it will tell you that also...
    Titch
    ade's Avatar
    ade
    Jul 2009
    Bromsgrove
    thanks for that,titch.
    i need a 43 tooth rear with standard 15 front,it should be ridable then as it s geared for speed,not good when running in!
  1. Best sprocket sizes
    By Warthog in forum Dominator / FMX
    Last Post: 30-12-09, 09:38 AM
  2. FMX Chain/Sprocket Sizes
    By seamus in forum Dominator / FMX
    Last Post: 15-10-08, 01:17 AM
  3. RD04 sprocket sizes
    By BobA in forum Africa Twin
    Last Post: 03-07-08, 10:12 PM
  4. Sprocket sizes
    By Hennie in forum Africa Twin
    Last Post: 21-05-07, 11:54 PM
  5. Standard sprocket sizes
    By howiezowie in forum Transalp
    Last Post: 26-03-07, 08:52 PM
