Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > XL
Reply
  #11 (permalink)
Old 08-02-10, 08:10 AM
catteeclan's Avatar
Senior Member
Re: help with starting XL250
Quote:
Originally Posted by dastardly View Post
i've checked the jet sizes, the main jet is 118 and the pilot is 35, i cant find an online place to check if this is correct.
I took the bike out for a spin once i got it started and it pulled really well once it got going, but still wont idle and start after you stop it.
what do you think i should do now? I have cleaned the carb again, the throttle valve was black so i have cleaned this up and it seems to slide better.
I have check the choke and it does have a rubber at the end of the plunger, but im not sure how to check to see if this is sitting correctly?
cheers again..!
Jet sizes sounds about right to me hopefully some-one can confirm this.
That choke plunger sits on an opening so maybe assembling with out the cable attached.
Another thing is the float hight, this can make it run rich if to high.
The needle valve can also leak but the carb will over flow with petrol if this is a prob.
Last thing I can think of is an internal crack, uncommon but I have heard of it.
__________________
08 TDM900,
96 Dominator,
84 XL600lm,
82 XL500r.
  #12 (permalink)
Old 08-02-10, 10:14 AM
416cc's Avatar
Red Blooded Biker
If you have a multimeter check/measure the resistance of the spark plug cap. If it's more than the spec replace it.
Many moons ago I had a problem with my bike. I replaced all sorts of bits on the bike until I read about how plug caps can give problems. I put a new NGK cap on & was surprised how many problems it cured.
Reply
Tags
plug, starting, xl250
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
XL250 K3 project Neilios XL 50 04-03-10 06:58 AM
Re: XL250 Motorsport Neilios XL 7 08-12-09 08:35 PM
XL250 Motorsport 416cc XL Technical Specs 0 05-12-09 01:45 PM
New Owner '86 XL250 in UK thedktor XL 10 15-01-09 09:58 PM
what else would fit my xl250 rear wheel rkid121 Bike Tech 3 14-02-08 11:19 AM
