Hello all, i wonder if you can help me before i start using a hammer...?
I have posted a number of other threads about a xl250 degree and i wonder if anyone can help me with this problem i have now?
I have replaced the CDI, cleaned up all the bad connections and the loom, now i have a spark, thats bright and looks right.
I have started the bike and it will run (occasionally) only from cold, or if i remove the spark plug (its a new one) and clean it up.
The bike has a keihin CV carb, that i have removed and cleaned up with carb cleaner and all the passageways and jets appear to be clear, i removed the pilot jet and checked that, refitted it to 1.5 turns as per the NX250 manual (cant find a degree manual anywhere).
If i do manage to get it started it wont idle, it doesn't smoke alot, but it will run until you let it.
After then it will not start, if i remove the plug it looks black, if i clean it up it will start after alot of cranking (electric start).
JUst wondered if you have any suggestions - i hope its not oil that i can see?
Cheers all
Rob
