Results 1 to 8 of 8
Thread: xl 250 engine strip
    escort is offline Junior Member
    Aug 2010
    blton
    xl 250 engine strip
    hi i am a new member to the forum and have just bought a 1980 250s , my queston is can the bottom crank case half be removed without stripping the whole engine as the kick start return spring has failed ? thanks for any help
    paul
    Pigford is offline Member
    Jun 2010
    Dorset UK
    Re: xl 250 engine strip
    I thought they were vertically split cases
    416cc's Avatar
    416cc is offline Red Blooded Biker
    Nov 2009
    NW Kent
    If the engine is a XL250S type then it's a horizontally split crankcase.
    honda crankcase 82 83 partsmanual fiche xl250s 80 xl250
    To replace the spring you'd only need to remove the clutch cover. While it's off then check the gauze oil strainer as this is the only filter on the bike.
    Jun 2010
    Dorset UK
    Thanx - I stand corrected
    catteeclan's Avatar
    Jun 2006
    Gorleston Norfolk
    Quote Originally Posted by 416cc View Post
    Sorry, the kickstart return spring is in the gearbox and I think it'll be difficult to change without a full engine strip.
    08 TDM900,
    98 Dominator,
    84 XL600lm,
    82 XL500r.
    416cc's Avatar
    Nov 2009
    NW Kent
    Jun 2010
    Dorset UK
    Blimey - we're all learning sumink today
    zetor12 is offline Junior Member
    May 2010
    Luxembourg
    If we are talking about item No. 7 from that fiche I think you can only get access by splitting the crankcase halfs.
  1. engine strip service parts?
    By redun in forum Dominator / FMX
    Last Post: 26-03-10, 08:34 PM
  2. Replies: 3
    Last Post: 10-08-09, 05:57 PM
  3. Strip Down to bare frame
    By smallfordsuk in forum Africa Twin
    Last Post: 01-04-09, 02:14 PM
  4. FlannyVision - strip your ktm blindfolded
    By Cie in forum Everything Orange - KTM
    Last Post: 12-10-08, 07:00 PM
  5. HELP! rear sus. strip/regrease anyone done this?
    By MCsanandreas in forum Transalp
    Last Post: 23-04-08, 08:54 PM
