Results 1 to 3 of 3
Thread: Can an xl250s run a 36mm TM Mikuni?
    Russ447's Avatar
    Russ447 is offline Junior Member
    Lincs
    Question Can an xl250s run a 36mm TM Mikuni?
    I am building a tuned xl250s - lightened ignition, bottom end, Joy cam. I was going to try a 43mm Mikuni, but I already have a 36mm TM flatslide (without accelerator pump). It will be a race bike so I don't have to worry about how it runs around town.
    Does any one have any experience of running this type of carb or something similar on an xl250? If you do I would be interested to hear how you got on - before I buy a suitable inlet manifold and lose several days playing with jets.
    Thanks,
    Russ
    Pigford is offline Member
    Jun 2010
    Dorset UK
    Thumbs up Re: Can an xl250s run a 36mm TM Mikuni?
    I'd have thought you'd be able to get it to run OK.
    If its a bit big - low down may suffer a bit (less torque), but it may well gain higher revs?
    Suck & see - part of the fun
    Russ447's Avatar
    Lincs
    Thanks - I think I will give it a go. If anyone has any ideas for a base line set up - needle/jets I would be interested to hear.
    US racers seem to think a 36mm will be ok, some even run 38s on super tuned stuff.
    Will let you know how I get on.
    Russ
  1. mikuni carb in the uk?
    By philj in forum XR
    Last Post: 28-04-10, 02:43 PM
  2. mikuni carb on dommie?
    By chAos ego in forum Dominator / FMX
    Last Post: 28-07-08, 06:07 PM
  3. Mikuni carbs
    By Beedog in forum XR
    Last Post: 04-04-08, 04:49 PM
  4. Mikuni fuel pump
    By mutongo in forum Africa Twin
    Last Post: 06-08-06, 07:28 PM
  5. Mikuni Fuel Pump
    Last Post: 14-06-05, 08:09 AM
