Xl125 lacking power
Results 1 to 6 of 6
Thread: Xl125 lacking power
    dune19670 is offline Junior Member
    May 2012
    essex
    Xl125 lacking power
    Hi all,
    My 84 xl125 rc starts & runs fine but lacks any top end power.
    Anyone got any ideas whats wrong.
    Ive changed cdi
    Checked timing
    New carb
    Its doing my head now ????
    Thanks steven
    mid life crisis is offline Senior Member
    May 2009
    under the thumb
    Re: Xl125 lacking power
    Fuel... new carb so unlikly to be that but chack the air filter and is there any wanter in the tank?? sounds stupid but i have had it happen before
    Electrical...... cdi's are normaly reliable, but whats the condition of the coil, ht lead and ht cap and spark plug?
    Then we are down to compression, and from what your saying, it sounds like that, you could do with getting it compression tested
    May 2012
    essex
    Hi there, thanks for the reply.
    The coil, ht lead & spark plug are all new.
    Ive put a new k&n air filter on,
    But it was the same with the old standard filter. ??
    So compression test is next, will this prove its the rings or could it be the valves
    Any more ideas please join in, steve
    May 2009
    under the thumb
    With a k+n have you jettered it acordingley? i found in my younger days that the small honda's did not like them, but that was a cg125 and a cm125.
    if there is a compresion problem, its a head of job for investigation to see what the problem is.
    May 2012
    essex
    I havnt jetted up the carb to suit the k&n,
    I'll put the standard one one again to see if it makes any difference.
    I'll see if i can borrow a compression tester at the weekend, does anyone know what a good/ bad compression reading is.
    Thanks for the input steve
    May 2012
    essex
    Well ive tested my compression today,
    Cold, and it was 120-125.
    Does anyone know if this is a good reading or not.???
    The manual says the compression ratio is 9.4-1,
    And ive seen a few conflicting exchange calculating figures.
    So i would appreciate some help here please.
    Thanks Steve
  1. Xl125 rc overheating help ??
    By dune19670 in forum XL
    Last Post: 10-06-12, 06:20 AM
  2. XL125, what's it worth
    By Snooky in forum What's it worth?
    Last Post: 16-01-12, 01:14 PM
  3. my xl125 rc
    By draclee in forum I'd like to introduce myself....................
    Last Post: 19-10-10, 11:30 PM
  4. Xr125l Vs Xl125
    By Critch in forum XR
    Last Post: 20-07-07, 03:04 PM
