Results 1 to 4 of 4
Thread: Honda XR650R Technical Specifications
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    This is a test thread to agree a layout for technical specifications threads on other bikes. Comments on usefulness, layout, etc.. very welcome.
    These specifications are intended as a guide and do not constitute official measurements or specifications. If you are unsure please get a Honda approved mechanic to check or maintain your bike.
    All units in millimetres mm (inches in) unless otherwise specified.
    Honda XR650R
    Covers the years (unknown).
    Covers the models:
    ED - European Direct Sales
    DK - General Export
    U - Australia
    Please post up specs of other variations if you have them.
    Pictures
    Dimensions
    Length: 2255 mm (88.8 in)
    Width: 825 mm (32.5 in)
    Height: 1245 mm (49.0 in)
    Wheelbase: ED, DK - 1425 mm (56.1 in), U - 1490 mm (58.7 in)
    Seat Height: 939 mm (37.0 in)
    Ground Clearance: 305 mm (12.0 in)
    Dry Weight: ED, DK - 131.0 kg (289 lbs), U - 133.0 kg (293 lbs)
    Curb Weight: ED, DK - 142.0 kg (313 lbs), U - 144.0 kg (317 lbs)
    Frame
    Frame Type: Semi-double cradle
    Front Suspension: Telescopic fork
    Front Wheel Travel: 285 mm (11.2 in)
    Rear Suspension: Swingarm
    Rear Wheel Travel: 307 mm (12.1 in)
    Front Tyre (Tire) Size: 3.00-21 51P
    Rear Tyre (Tire) Size: 4.50-18 70P
    Tyre (Tire) Brand FR/RR: TR8/TR8 (IRC)
    Front Brake: Hydraulic single disc
    Rear Brake: Hydraulic single disc
    Caster Angle: 27 degrees 32'
    Trail Length: 108 mm (4.3 in)
    Fuel Tank Capacity: 10.0 l (2.64 US Gal, 2.2 Imp Gal)
    Fuel Tank Reserve Capacity: 4.5 l (1.19 US Gal, 0.99 Imp Gal)
    Engine
    Type: Petrol (Gasoline), liquid cooled 4-stroke SOHC
    Cylinder Arrangement: Single cylinder inclined 13 degrees
    Bore and Stroke: 100.0 x 82.6 mm (3.94 x 3.25 in)
    Displacement: 649 cm cubed (39.6 cu-in)
    Compression Ratio: 10.0:1
    Valve Train: 4-valve, single chain driven SOHC
    Intake Valve Opens: 15 degrees BTDC
    Intake Valve Closes: 45 degrees ABDC
    Exhaust Valve Opens: 45 degrees BBDC
    Exhaust Valve Closes: 15 degrees ATDC
    Lubrication System: Forced pressure and dry sump
    Oil Pump Type: Trochoid/double rotor
    Cooling System: Liquid cooled
    Air Filtration: Oiled polyurethane foam
    Engine Weight: 40.9 kg (90.2 lbs)
    Carburettor (Carburetor)
    Carburettor (Carburetor) type: Piston valve
    Throttle Bore: 42 mm (1.7 in)
    Drive Train
    Clutch System: Multi-plate, wet
    Clutch Operation System: Cable operating
    Transmission: Constant mesh, 5 speeds
    Primary Reduction: 1.651 (71/43)
    Final Reduction:
    ED, DK - 3.429 (48/14)
    U - 2.733 (41/15)
    Gear Ratio 1st: 3.083 (37/12)
    Gear Ratio 2nd: 2.125 (34/16)
    Gear Ratio 3rd: 1.666 (30/18 )
    Gear Ratio 4th: 1.333 (28/21)
    Gear Ratio 5th: 1.115 (29/26)
    Gearshift Pattern: Left operated return system 1 - N - 2 - 3 - 4 - 5
    Electrical
    Ignition System: CDI (Capacitive Discharge Ignition)
    Lubrication System
    Engine Oil Capacity:
    at draining 1.56 l (1.65 US qt, 1.37 Imp qt)
    at disassembly 2.0 l (2.1 US qt, 1.8 Imp qt)
    at filter change 1.6 l (1.7 US qt, 1.4 Imp qt)
    Recommended Engine Oil: Honda 4-stroke oil or equivalent motor oil. API service classification: SE, SF or SG Viscosity.
    Oil Pump Rotor:
    Tip clearance: 0.15 (0.006)
    Body clearance: 0.15 - 0.22 (0.006 - 0.009)
    Side clearance: 0.03 - 0.08 (0.001 - 0.003)
    Fuel System
    Carburettor Identification Number:
    ED, DK: PE78C
    U: PE78D
    Main Jet:
    ED, DK: #175
    U: #112
    Slow Jet: #65
    Jet Needle Clip Position: 3rd groove from top
    Pilot Screw Opening: Factory setting 1 3/4 turns out
    Float Level: 16.0 mm (0.63 in)
    Idle Speed: 1400 +/- 100 rpm
    Throttle Grip Free Play: 2 - 6 mm (1/16 - 1/4 in)
    Cooling System
    Coolant Capacity:
    Radiator and engine: 1.52 l (1.61 US qt, 1.34 Imp qt)
    Reserve tank: 0.20 l (0.21 US qt, 0.18 Imp qt)
    Radiator Cap Relief Pressure: 108 - 137 kPa (1.1 - 1.4 kgf/cm squared, 16 - 20 psi)
    Thermostat:
    Begins to open: 80 - 84 degrees C (176 - 183 degrees F)
    Fully open: 95 degrees C (203 degrees F)
    Valve Lift: 8mm (0.3 in) minimum
    Standard Coolant Concentration: 50% mixture with soft water
    Cylinder Head / Valves
    Decompressor Lever Free Play: 5 - 8 mm (3/16 - 5/16 in)
    Cylinder Compression:
    Valve clearance at standard (decompressor applied): 600 kPa (6.12 kgf/cm squared, 87 psi) at 400 rpm
    Valve clearance at 1 mm (0.04 in) (decompressor not applied): 1100 kPa (11.22 kgf/cm squared, 160 psi) at 400 rpm
    Valve Clearances:
    IN: 0.15 +/- 0.02 (0.006 +/- 0.001 )
    EX: 0.20 +/- 0.02 (0.008 +/- 0.001 )
    Clutch
    Clutch Lever Free Play: 10 - 20 (3/8 - 3/4)
    Clutch Spring Free Length: 49.0 (1.93)
    A (6 Discs): 45.5 (1.79) Service Limit - 44.5 (1.75)
    43.2 (1.70) Service Limit - 41.6 (1.64)
    Clutch Disc Thickness:
    A (6 Discs): 3.22 - 3.38 (0.127 - 0.133) Service Limit 3.00 (0.118 )
    B (1 Disc): 2.92 - 3.08 (0.115 - 0.121) Service Limit 2.69 (0.106)
    Clutch Plate Warpage Service Limit: 0.30 (0.012)
    Front Wheel / Suspension / Steering
    Cold Tyre (Tire) Pressure: 175kPa (25 psi)
    Front Wheel Rim Runout Service Limit: Radial 2.0 (0.8 ), Axial 2.0 (0.8 )
    Fork Spring Free Length: 506 (19.9) Service Limit 496 (19.5)
    Fork Tube Runout Service Limit: 0.20 (0.01)
    Recommended Fork Oil: Pro Honda Suspension Fluid SS - 7
    Fork Oil Level: 120 (4.7)
    Fork Oil Capacity: 637 cc
    Compression damping adjuster standard position: 11 clicks out from full in
    Rebound damping adjuster standard: 9 clicks from full in
    Rear Wheel / Suspension
    Cold Tyre (Tire) Pressure: 125 kPa (18 psi)
    Rear Wheel Rim Runout Service Limit: Radial 2.0 (0.8 ), Axial 2.0 (0.8 )
    Drive Chain Slack: 20 - 30 (13/16 - 1 3/16)
    Drive Chain Length (at 41 pins / 40 links) Service Limit: 638 (25.1)
    Drive Chain Size / Link:
    ED, DK: DID 520VM-110LE or RK520KZO-110LE
    U: DID 520VM-108LE or RK520KZO-108LE
    Compression damping adjuster standard position: 6 - 10 clicks out from full in
    Rebound damping adjuster standard position: 11 - 15 clicks out from full in
    Disc Brakes
    Specified Brake Fluid: Dot 4
    Brake Disc Thickness:
    ED, DK: 2.8 - 3.2 (0.11 - 0.13) Service Limit 2.5 (0.10)
    U: 3.3 - 3.7 (0.13 - 0.15 ) Service Limit 3.0 (0.12)
    Brake Disc Runout: Service Limit 0.20 (0.008 )
    Electrical System
    Spark Plug:
    Standard Riding: NGK BKR7E-11, DENSO K22PR-U11
    High Speed Riding: NGK BKR8E-11, DENSO K24PR-U11
    Spark Plug Gap: 1.0 -1.10 (0.039 - 0.043 )
    Headlight Bulb: 12 V 35/35 W
    Taillight Bulb: 12V 21/5 W
    Torque Values
    Unless specified all bolts should be tightened to the following torque values.
    Standard Fasteners N-m (kgf-m, lbf-ft):
    5 mm Bolt and Nut: 5 (0.5, 3.6)
    6 mm Bolt and Nut: 10 (1, 7)
    8 mm Bolt and Nut: 22 (2.2, 16)
    10 mm Bolt and Nut: 34 (3.5, 25)
    12 mm Bolt and Nut: 54 (5.5, 40)
    5 mm Screw: 4 (0.4, 2.9)
    6 mm Screw: 9 (0.9, 6.5)
    6 mm Flange Bolt (8 mm Head: Small Flange): 9 (0.9, 6.5)
    6 mm Flange Bolt (8 mm Head: Large Flange - engine only): 12 (1.2, 9)
    6 mm Flange Bolt (10 mm Head) and Nut: 12 (1.2, 9)
    8 mm Flange Bolt and Nut: 26 (2.7, 20)
    10 mm Flange Bolt and Nut: 39 (4.0, 29)
    Engine N-m (kgf-m, lbf-ft):
    Valve Adjust Cover Hole Bolt 4 x 6 mm: 12 (1.2, 9)
    Oil Drain Bolt (at crankcase) 1 x 12 mm: 25 (2.5, 18 )
    Valve Adjusting Lock Nut 4 x 8 mm: 25 (2.5, 18 )
    Spark Plug 1 x 14 mm: 18 (1.8, 13)
    Oil Pump Plate Bolt 2 x 6 mm: 12 (1.2, 9)
    Water Pump Assembly Bolt 2 x 6 mm: 13 (1.3, 9)
    Thermostat Housing Cover Bolt 2 x 6 mm: 12 (1.2, 9)
    Cylinder Head Nut 4 x 10 mm: 44 (4.5, 33) NOTE 4
    Head Cover Bolt 2 x 8 mm: 23 (2.3, 17)
    Head Cover Bolt 8 x 6 mm: 12 (1.2, 9)
    Cam Sprocket Bolt 2 x 7 mm: 20 (2.0, 14) NOTE 1
    Cam Chain Tensioner Bolt 2 x 6 mm: 12 (1.2, 9) NOTE 1
    Cylinder Bolt 2 x 6 mm: 12 (1.2, 9)
    Kickstarter Pedal Pinch Bolt 1 x 8 mm: 37 (3.8, 27)
    Flywheel Bolt 1 x 12 mm: 127 (13.0, 94) NOTE 4
    Left Crankcase Cover Stud Bolt 4 x 6 mm: 12 (1.2, 9)
    Timing Hole Cap 1 x 14 mm: 10 (1.0, 7)
    Frame N-m (kgf-m, lbf-ft):
    Exhaust Pipe Joint Nut 4 x 8 mm: 18 (1.8, 13)
    Exhaust Pipe Clamp Bolt 1 x 8 mm: 20 (2.0, 14)
    Muffler Mounting Bolt 2 x 8 mm: 32 (3.3, 24)
    Muffler Clamp Bolt 1 x 8 mm: 20 (2.0, 14)
    Exhaust Pipe Protector Bolt 2 x 6 mm: 12(1.2, 9)
    Maintenance N-m (kgf-m, lbf-ft):
    Fuel Valve Mounting Bolt 2 x 6 mm: 9 (0.9, 6.5)
    Down tube Oil Drain bolt 1 x 8 mm: 39 (4.0, 29)
    Rear Brake Pedal Adjuster Lock Nut 1 x 8 mm: 18 (1.8, 13)
    Side Stand Pivot Nut 1 x 10 mm: 39 (4.0, 29)
    Spark Arrestor Bolt 3 x 6 mm: 12 (1.2, 9)
    Rim Lock 2 x 8 mm: 13 (1.3, 9)
    Lubrication N-m (kgf-m, lbf-ft):
    Down Tube Oil Strainer 1 x 27 mm: 54 (5.5, 40)
    Oil inlet Pipe Bolt 1 x 12 mm: 37 (3.8, 27)
    Front Wheel / Suspension / Steering N-m (kgf-m, lbf-ft):
    Front Brake Disc Bolt 4 x 6 mm: 20 (2.0, 14) NOTE 1
    Front Axle 1 x 16 mm: 88 (9.0, 65)
    Front Axle Holder Nut 4 x 6 mm: 12 (1.2, 9) NOTE 5
    Fork Center Bolt 2 x 27 mm: 54 (5.5, 40) NOTE 1
    Fork Cap Bolt 2 x 43 mm: 30 (3.1, 22)
    Steering Stem Nut 1 x 24 mm: 98 (10.0, 72)
    Rear Wheel / Suspension / Steering N-m (kgf-m, lbf-ft):
    Rear Brake Disc Bolt 4 x 6 mm: 20 (2.0, 14) NOTE 1
    Rear Axle Nut 1 x 16 mm: 93 (9.5, 69) NOTE 5
    Driven Sprocket Nut 6 x 8 mm: 42 (4.3, 31) NOTE 5
    Swingarm Pivot Nut 1 x 18 mm: 108 (11.0, 80) NOTE 5
    Shock Absorber Upper Mounting Nut 1 x 10 mm: 44 (4.5, 33) NOTE 5
    Shock Absorber Lower Mounting Nut 1 x 10 mm: 44 (4.5, 33) NOTE 5
    Shock Arm-to-Swingarm Nut 1 x 12 mm: 78 (8.0, 58 ) NOTE 5
    Shock Link-to-Shock Arm Nut 1 x 12 mm: 69 (7.0, 51) NOTE 5
    Shock Link Nut 1 x 12 mm: 69 (7.0, 51) NOTE 5
    Shock Absorber Spring Lock Nut 1 x 56 mm: 29 (3.0, 22)
    Swingarm Pivot Lock Nut 1 x 28 mm: 64 (6.5, 47)
    Side Stand Mounting Bolt 1 x 8 mm: 26 (2.7, 20)
    Side Stand Mounting Bolt 2 x 10 mm: 39 (4.0, 29)
    Hydraulic Brake N-m (kgf-m, lbf-ft):
    Brake Hose Oil Bolt 4 x 10 mm: 34 (3.5, 25)
    Brake Lever Pivot Bolt/Nut 1/1 x 6 mm: 6 (0.6, 4.3)
    Brake Lever Adjuster Lock Nut 1 x 5 mm: 6 (0.6, 4.3)
    Front Caliper Mounting Bolt 2 x 8 mm: 29 (3.0, 22) NOTE 1
    Caliper Bleed Valve 2 x 8 mm: 6 (0.6, 4.3)
    Rear Master Cylinder Mounting Bolt 2 x 6 mm: 12 (1.2, 9)
    Pad Pin 2 x 10 mm: 18 (1.8, 13)
    Pad Pin Plug 2 x 10 mm: 3.0 (0.3, 2.2 )
    Front Caliper Pin Bolt 1 x 8 mm: 23 (2.3, 17) NOTE 1
    Front Caliper Bracket Pin Bolt 1 x 8 mm: 23 (2.3, 17) NOTE 1
    Rear Caliper Pin Bolt 1 x 12 mm: 27 (2.8, 20)
    Rear Caliper Bracket Pin Bolt 1 x 8 mm: 13 (1.3, 9) NOTE 1
    Brake Pdeal Pivot Bolt 1 x 8 mm: 25 (2.6, 19)
    Rear Master Cylinder Push Rod Lock Nut 1 x 8 mm: 18 (1.8, 13)
    NOTE 1: Apply locking agent to the threads.
    NOTE 2: Apply grease to the threads and seating surface.
    NOTE 3: Stake.
    NOTE 4: Apply oil to the threads and seating surface.
    NOTE 5: U-nut
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Mudwiz's Avatar
    Re: Honda XR650R Technical Specifications
    Easy way is :
    "Hang on!" .
    416cc's Avatar
    416cc is offline Red Blooded Biker
    Nov 2009
    NW Kent
    kaupo is offline Junior Member
    Jan 2008
    ESTONIA
    Can anyone share the info on the eye-to-eye length of a XR650R rear shock unit? Googled it without any luck. Thanks!
  1. Honda XR400R Technical Specifications
    By DaveS in forum XR Technical Specs
    Last Post: 25-11-11, 05:46 PM
  2. Honda XR650R for swap, maybe sale.
    By UKRob in forum For Sale / Wanted
    Last Post: 21-03-08, 03:01 PM
  3. Is a technical webinar possible?
    By GeoBloke in forum Chatter
    Last Post: 25-02-07, 02:17 PM
  4. Specifications
    By The Civil One in forum Africa Twin
    Last Post: 02-11-05, 12:50 PM
