1 - 11 of 11 Posts
Hi
Managed to spill liquid superglue which has run down the front sprocket cover of my 2009 varadero - anyone have a paint match for it?
David
Hi
David
Why does it need painting? could you not use a thinners to remove the superglue??
G
Hi
David
Ask your Mrs if you can have some nail varnish remover ( acetone). What ever you use, try it on a hidden area first to see if it does anything parculiar to the finish.
Hope this is of help
Josh
Jeezus David, the way your going mine will be more inmmaculate by May than your 09er....
Josh
Will give this a try but I'm not hopeful - it's industrial superglue and I think it has eaten through the paint!
Quite possibly!!!!! :sad:
Never mind mate, done similar many yrs ago, was fitting Datatag senders to an @T and while putting one in the petrol tank dropped epoxy resin on the tank! :confused:
At least it did come off with acetone! Better luck next time! :thumbup:
1 - 11 of 11 Posts
