EFi vara's have got to have one of the easiest service schedules. IIRC valves and and plugs are every 32,000 miles. Oil every 8,000 with the air filter annoyingly every 12,000. But stick a K&N in and you can get away with just changing the oil and a general check over for three consecutive services, then a big one where you check valves, change coolant and brake fluid. I paid Blackpool Honda about £220 for all that 2 years ago. The deal was a check only, if adjustment needed it would have been more. You rarely hear of the bikes needing adjustment until V high miles.Cheers Jason. Any idea on the time needed for a valve check only? I know my TA was around £180, 2-3 years ago.
I am just trying to get an idea of likely costs for some work needing to be done on a possible purchase...
The full 16k service was about £180, alot of the work didn't need doing i had already changed brake fluid they checked that and coolant didn't need changing still within limits. They did the valve check and carb balance which needed no adjustment changed air filter, plugs, and oil and oil filter. I did give them the bike for the full day dropped it there the night before as valves have to be done cold.Cheers Jason. Any idea on the time needed for a valve check only? I know my TA was around £180, 2-3 years ago.
Thanks muchly Austin, it sounds better by the minuteEFi vara's have got to have one of the easiest service schedules. IIRC valves and and plugs are every 32,000 miles. Oil every 8,000 with the air filter annoyingly every 12,000. But stick a K&N in and you can get away with just changing the oil and a general check over for three consecutive services, then a big one where you check valves, change coolant and brake fluid. I paid Blackpool Honda about £220 for all that 2 years ago. The deal was a check only, if adjustment needed it would have been more. You rarely hear of the bikes needing adjustment until V high miles.
On the CBS systems the rear pads wear quickly - I got about 8k out of mine. Fronts about twice as long.
Hope the bike you have seen is a good 'un.
Thanks for that info, it does sound as if the local Honda dealers were taking the pi$$ wanting £500!!!! I will ask the local unfranchised dealers who do my MOT and odd job if i have no joy with the other chap.The full 16k service was about £180, alot of the work didn't need doing i had already changed brake fluid they checked that and coolant didn't need changing still within limits. They did the valve check and carb balance which needed no adjustment changed air filter, plugs, and oil and oil filter. I did give them the bike for the full day dropped it there the night before as valves have to be done cold.
Can't agree with Austin about brake pads with CBS mines done 35k and i have used 1 set on the rear and 2 on the fronts
Mmm, valve work like that is beyond a simple farmer like me, my feeler gauges are rusted solid anyway. :thumbup:You will have to do a lot of miles to get your money back on a K&N. I'd just change the air filter as per manufacturers guidelines.
The valve check is reasonably straight forward but should one need adjusting then thats a camshaft out job so can get expensive. In saying that anecdotal evidence suggest that they rarely need doing so if you are concerned check them yourself and if necessary you can either reshim them yourself or have a dealer do it.
Apart from adjusting valves the bikes are a doddle to work on.
Nice one Steve. Glad you've finally found something that yo can make your own and ride without pain.Done a deal on a 2005 black Vara, ...
£500 would be about right if they do everything on the service schedule as it would take about 2-3 hours longer than mine took, if you say £60p/hour thats an extra £180. Mine was done by a honda dealer but they checked everything first to see if it needed doing, if it didn't need doing they didn't do it so the price was cheaper and they told me what didn't get done like coolant and brake fluid when i picked the bike up. Easy to dip the coolant and brake fluid with a hydrometer to see if it's serviceable.Thanks for that info, it does sound as if the local Honda dealers were taking the pi$$ wanting £500!!!! I will ask the local unfranchised dealers who do my MOT and odd job if i have no joy with the other chap.
On the brake pad issue, I am far too polite to suggest it may be rider style or the "mass" being carried.
I reckon if I go for the Vara, the brakes will have a VERY hard time with 26 stone+ on board, so the pads will need to be spot on when negotiating the wee roads in the Highlands!!![]()
Didnt know you could check the brake fluid! I am hoping to get a local bike mechanic to do the wee jobs that I am reluctant to tackle.£500 would be about right if they do everything on the service schedule as it would take about 2-3 hours longer than mine took, if you say £60p/hour thats an extra £180. Mine was done by a honda dealer but they checked everything first to see if it needed doing, if it didn't need doing they didn't do it so the price was cheaper and they told me what didn't get done like coolant and brake fluid when i picked the bike up. Easy to dip the coolant and brake fluid with a hydrometer to see if it's serviceable.
There's loads of different tools for testing brake fluid properly but all cost a bit, if in doubt just change it, it's an easy job to do.Didnt know you could check the brake fluid! I am hoping to get a local bike mechanic to do the wee jobs that I am reluctant to tackle.I will ask if he can check both the fluids as you suggest. Ta.
Sent from my GT-P1000 using Tapatalk 2
As you say, they cost a few bob and with only a small stable to ride, (compared to some here!) probably not cost effective really.There's loads of different tools for testing brake fluid properly but all cost a bit, if in doubt just change it, it's an easy job to do.
