Unlike my old XR250 (1994) which had a paper element oil filter, the older XL just has a wire mesh oil filter, at the bottom of the sump. :rolleyes:
So, as the bike is quite new to me, and been off the road since 1996, with 18000 miles I decided to check it out.
Its a bit of a pain, coz you need to remove the r/h clutch casing to access it, which means footrest, kickstart, clutch & auto-decomp cables, sump guard, etc :pale:
Anyhow, got to it and pulled it out, and it was nigh on clean - just a few bits of gundge - which is probably clutch material :confused:
So, come the putting it back together bit - new gasket, copper-slip the bolts - and only bit to note is hold the kickstart auto de-compression lever back (anti-clockwise) whilst assembling :thumbup:
Re-filled with semi-synth motorcycle oil & thats it for another 8000 miles (as per manual) :teeth:
8,000 miles without an oil filter???
No bloody chance!!!
Cheap, mineral oil, changed every thousand miles for me dude!!!
No bloody chance!!!
No, No, Noooooooooooooo, thats 8000 miles for the mesh filter clean - I do oil about every 1000mile, or 2000 max :D
