A man without Ale.
Okay guys.
rare as hens teeth here. but i just found a wheel off 1990 AT, I was thinking that i may grab it for the hub (so i can lace up a 18" X2.5rim). But will it fit?
Xander
Wing Commander
Yes.
The RD04 rim was narrower than the RD07 but the hub is the same. Get a narrow 18 rim, if you are planning mud or a wider one for more choice of tyres.
Toolbox
front hubs ,,, africa`s and transalps ,,,, all years all the same
Just so not anyone is fooled by this at a later date: There are Africa Twins RD03 with only one brake disk in the front, which calls for a different front hub.
Chris
Señor Member
Anyone know if any other hubs would be compatible with a rear off an RD07a? I'm after one so that I can have a new rear built...
