Good day I am unfortunately not a Varadero owner but ride a AT. I am trying to assist a friend on a Varadero. His Problem is as follows. He uses around 1,5 L of oil for every 1000km he does. He does not over ref or burn the bike. Valve stem seals or rings?
Also is there a online workshop manual available?
All help will be greatly appreciated.Regards.
That's a hefty oil use, I would ask first is it synthetic or semi? Synth tends to burn a bit more, perhaps try changing to semi and see if it's still as bad. I'd say probably rings rather than valves. I've not heard of the engine having a thirst for oil?
There are plenty of electronic copies out there, I bought a cd version from Ebay years ago.
It would be best if you bought a copy from your friendly Honda dealer, it would supply more info than any you could hope to get elsewhere.
Truffle shuffle king
hi I have. 99 varadero and have done 1,500km since I bought it in December. Sofar I have used no oil to talk of. The temperature hereis in the low since finger centigrade. The bike has done 81,500km
I am not knowledgable about the why and what's for your problems but thought it might help you compare.
Regards
Gary
Is this any help
____________________________________________________
Mod edit by Boris to remove link to copyright material.
Please don't post these links as they contravene the forums T&C
______________________________________________________
Loudpedal
Dont you get different coloured exhaust smoke from ring and valves i seem to remember! worth checking out! try this for a manual i think there is a Vara on ther---
