After doing a bit of research, and removing the actual bearings im a little confused. Found on forums that linkage bearings were TA1720Z (O.D 24mm, I'D 17mm, Width 20mm) The ones i removed from bike were BM172417-1 (O.D 24mm, I.D 17mm, Width 17mm) Any idea which is the correct bearing to go for??
No, to be honest they were in really good condition. Looks like they have recently been changed. I only removed them as I'm getting some parts powder-coated. I pressed them out, so could probably be re-used, but think I'll put new ones in
Stone Crazy
Check out wemoto they do kits for some bikes with all the bearings and seals you need
Thanks for info The only ones i need to order now, are they swing arm bearings. Any one have a part number for these. Looking at various websites, they only give the sizes (O.D 26mm, I.D 20mm and width 20mm)
I checked Fowlers, but it only gives the bearing size, and not the part number. I'l have to see if i can reference the sizes on a bearing supplier website
