1 - 12 of 12 Posts
Dave this is a well known problem on the CRF's and it happened to me , only solution when the spokes no longer tighten up is to have a re spoke
Every Honda CR or CRF I have had has done the same, I tighten mine after every ride and the only solution is to have them respoked using HD spokes, I use a local guy but if he is busy Talon do a good set.
What are HD spokes?
excuse my ignorance
The spokes on the rear wheels of my new 450s are constantly loosening up. I check them before (and during!) every ride and they always need tightening. Anyone else had this problem?
Take the tyre off and put a small bit of loctite in the screw then tighten them up. You can break loctite easily enough when they need adjusting with gentle heat. Or buy a tube of Chemical metal and put in the threads that will increase the friction and stop them unwinding but won't go hard like loctite
sfx wheels
waste of time loctite ing fresh air , if theres a gap at the tyre side of the nipple bigger than a couple or 4 mill where the spoke should be , then theres no thread embedment in the nipple
ie the spokes are too short !!!!!!! , take the tyre and rim tape off and have a look see ,,,,,,,,,,, theres only 2 reasons why spokes will constantly come loose
1 , nipple and spokes are not both the same thread gauge ,,,,,,, surprisingly not that un common , especially when someone decides to replace rusty nipples with new aftermarket ones
2 , the spokes arent long enough ,,,,,,,,,,,,,,,,
1 - 12 of 12 Posts
