21 - 23 of 23 Posts
I have just attempted to soften the rear suspension settings after having a couple of spine jarring experiences during our last ride out. I found that the shock was set to fully soft. What setting should I try next ?
Falcon Shocks(he is an old friend) told me yesterday that a typical overhaul cost for a rear shock would be approximately £250.00. Quick turnaround.
What are you softening?
If it's like the 650 the damping adjuster will have very little affect in handling or ride quality (unless fully laden).
How is the preload/sag? Is it bottoming or topping out?
That sounds expensive.
Kais serviced a 650 shock a couple of years ago for about £100 as I recall, and made no difference to previously.
As an aside, they have a bladder that can be recharged via a schraeder valve, I'm not sure what pressure they run at (believe it can be 150psi?) Or what affect it has on ride & handling but may be worth checking.
Is the swingarm pivot & linkage free & greased?
21 - 23 of 23 Posts
