Hello everyone,
I'm having a difficult time removing my 350's engine. I've followed the manual and have removed everything and I've even removed all the engine mounts. However, when I try to remove the lower left engine bolt it doesn't have enough room to come out before it hits the frame. I've supported the motor with a jack and the bolt slides in and out there's just not enough room for it to slip out all the way. Has anyone else encountered this? Is there a trick to remove it?
Thanks.
Sent from my SM-G892A using Tapatalk
Thanks.
