1 - 2 of 2 Posts
1998, 73kmiles....2nd gear rattle/grind. So, bitten the bullet & ive just ordered most of the parts (oem £:cry:) needed in preperation for engine rebuild, gaskets, gearbox bearings, cam chains, tensioners, oil/valve seals etc bloody etc. Main bearings/shells after the engine is split. Depending on what we find (hoping it's countershaft bearing) may be ordering other stuff. But... not working at the moment, so just wondering if i could use the parts from a 30k miles 90-93 gearbox eg: selector arms, 2nd gears & counter shaft (good splines). Only going to split this engine once, but want to make it as good as, with the finances available.
1 - 2 of 2 Posts
