1 - 20 of 57 Posts
Well finally got the bloody thing MOT'ed today after a lot of aggro, but now it wont bloody run!! Feels like it's over-fueling? the idle is very low and raising it on the throttle butterflies makes it act funny. Now it seems to bog down when accelerating and only does about 40mph max, it cuts out when I slow down.
Any ideas?? It has a facet fuel pump fitted if thats of any importance.
REALLY want to go ride tomorrow so any suggestions?
are there any adjustments on the carb that could affect its running?
Are the chokes stuck on?
Wild guess.
Hmmmm I don't think so, the choke lever doesn't appear to do too much really (I assume that fully out is choke off and into the bar is choke on? ) it doesnt do much, but if I pull it in the bike does cut out so I assume it is working and not stuck on.
Wondering if it could be the fuel, its been stood for a few months, it ran fine this morning though however I did put some petrol I had in my garage in, it's not all that old though :mad: guess I should drain the tank, check the filters not blocked then fill up with fresh petrol as the next step.
hedgerow specialist...
I know i`vw got the Alp but:blob6:
does it start at all when the engine cold? if not it aint the choke sticking
if it starts cold then when hot won`t start its prob the carb choke plungers stuck on , common prob easily fixed just unscrew plastic nut thingy and squirt with wd40 while pull/push choke.
have you checked the easy to get at plugs to see if its getting "overfueled"
take it that it ran okay before -noticed you only just got it from another member, have you tried him as most people on hear are real friendly like:thumbright:
drain the carbs into a small bowl and see what **** comes out, prob blocked jets-major strip down = lost weekend
do you have a haynes manual? I`m local and part of the borrowers guild:sign5: :sign5:
It starts hot and cold, but idles really low then is unrideable as it just bogs too much, not entirely sure how to tell if somethings over or under fueled when riding, but it just seems to be struggling a lot, won't go fast, won't pull away properly and likes to cut out as soon as I let the revs drop... however it will idle.....
I'm going to go and drain all the petrol, check the fuel filter and then top up with fresh fuel and see if that makes any difference.. I'll also check the choke lever isn't sticking and spray with WD40 as you suggest.
Weird this is it was fine yesterday.
Does the reserve tap pipe sit quite high in the tank??? It's got petrol in for sure but not a great deal, wondering if the reserve pipe sits fairly low and isn't picking up enough fuel hmm.
How old do you reckon that petrol actually was? I have an interest because I left some for 10+ years and it was like treacle - glued up everything, jets slides plugs etc and needed a complete strip down. Anyhow, here's an Oz guide that I found sort of interesting.
How long does fuel last?
This is an important question when you’ve got a car that’s rarely driven or you have fuel stored in drums. The last thing you want is a tankful of ‘off’ fuel that can damage your fuel system or possibly even kill your engine.
According to Shell Australia’s Technical Advice Centre Manager, Warren Scott, you can generally store fuel in a sealed container for around six months before it starts to deteriorate. This assumes it’s kept relatively cool and away from direct sunlight.
“But if the container is not properly sealed or it’s repeatedly opened, [fuel] will start to evaporate and you lose some of the light components in the fuel,” Mr Warren says.
Those light components include highly important butane. As these components are lost, the fuel loses its volatility. Mr Warren says this makes the car difficult to start.
In warm conditions, fuel is especially prone to oxidisation which causes lacquer and gums to form. As a result, the fuel turns dark in colour, loses its clarity and smells like paint stripper.
Gary Whitfield, Senior Fuel Chemist at BP Australia, says that in the right conditions, fuel can last up to 12 months. But once the container is opened, the fuel will start to degrade.
“Once the seal is broken, a vapour space is formed in the container and the fuel will start to deteriorate more rapidly,” he says.
Okay, so what about fuel that’s left in your car’s tank for a long period of time?
Mr Whitfield claims fuel in a car’s tank can last for up to four weeks before it becomes considerably denser. When this happens, the engine is effectively over-fuelled (without any change in injector pulse-width) and there’s an increased chance of carbon deposition onto spark plugs and inside the combustion chamber. This can cause driveability problems such as stutters and misses.
“Regular unleaded fuel will lose a small amount of octane over time but in our low-sulphur and high detergent Ultimate fuel it might increase very slightly. It might increase 1 RON in four weeks – but it’s not something I’d bother chasing,” he says.
“Keep in mind that typical variation in BP Ultimate is 98 – 100 RON while normal unleaded ranges between 91 – 93 RON.”
Mr Warren says that in most cases, it’s only when fuel is left in the tank for several months there’s the risk of engine damage. This is much more likely to occur in cars running dual LPG/petrol systems.
“By this time the fuel will have gone dark and gummy and can clag the fuel pump, filter and injectors,” Mr Warren says. It can also leave a lacquer deposit on the inside of the fuel tank which is difficult to remove.
In addition, it’s important to be aware that fuel brews – specifically fuel volatility - varies on a month to month basis. Standards vary from state to state but, generally, volatility is reduced during summer months to reduce evaporative emissions. Mr Whitfield says this typically makes the engine slightly harder to start but there is no change in octane.
Lachlan Riddel, proprietor of Gold Coast based tuning company ChipTorque, frequently dyno tests cars which have not previously been driven for several weeks.
“On the fuel mix we have in Queensland, I think fuel in a car’s tank is starting to go off in around three weeks,” Mr Riddel says. “We can tune a car, put it away for three of four weeks, come back to it and it will be either closer to detonation or less likely to make the same power.
“I think local fuel is brewed to reduce evaporative emissions in warm weather and, maybe because of that, fuel really goes crappy in eight to ten weeks. By that stage, the fuel is extremely prone to detonation.”
Interestingly, Mr Riddel hasn’t noticed the engine becoming harder to start but the effect on octane is pronounced.
Similarly, the General Manager of Melbourne’s Advanced Vehicle Operations, Steve Coates, believes fuel tends to go off in a car’s fuel tank quite quickly once it’s a couple of weeks old.
“After a couple of weeks not driving a car, I find that it will be closer to detonation than it was at the time of tuning on the chassis dyno,” he says.
“And the brand of fuel seems to make a difference as well – I find that Mobil and BP products are probably the best after being stored but Shell Optimax is really good when it’s new."
Clearly, there are some important factors to keep in mind when storing fuel in a container for several months or when parking your car for a few weeks.
Our recommendation is not to run the engine at high load with fuel that’s been in the tank for any more than three of four weeks and it’s a good idea to add at least 25 percent fresh fuel to the tank every few weeks. This will help ensure there are no fuel-related driveability problems or detonation and will reduce the chance of lacquer building up inside the tank.
Discussion Starter · #8 ·
The fuel has probably been in there for about 3 months at a guess... I've just drained it, it didn't look any different to normal petrol to be honest. I've topped up with some fresh petrol and it's no different... the fuel filter doesn't appear to be blocked and spark plugs are okay, black.. but they weren't excessively wet.
It ran fine yesterday and seemed okay this morning too?!? the only thing I've done in that time is all new gaskets on the exhaust (as it didn't have any and was blowing from every single joint, the lower collector box is rotten and needs replacing :( ) but I rode to the bike shop after that and it seemed fine too, it's just since picking it up from honda it's gone completey fooked!
Currently wishing I'd spent the extra on an 950 Adventure :D
Hill Rider
Sounds to me as if the chokes are stuck on.
Check a spark plug from both front & rear cylinders for colour. If either or both are wet & black, your chokes are stuck on.
where next?
Me too. The choke plungers need cleaning and lubing, and clean or replace the plugs (only 2 quid each at Rugged Roads last time I checked - bargain!). Blackened plugs won't be giving clean sparks. Stick with it. The KTM has got nothing on the mighty Africa Twin.
hi ,
do you want me to pop over tommorow am with me manual and acf spray for the choke plungers, and me honda spark plug tool:eek:, 2 minds are better than one.
if it ran yesterday it cant be to serious,
if so just put up you postcode and house number or email address but use At rather than @ to safe guard against spam:mad:
Russ
quick & easy. if the tanks over half full, by-pass the fuel pump. gravity-fed works if theres enough fuel, elliminates 1 possibility. good luck
Discussion Starter · #14 ·
hi ,
Russ
Hi cheers for the offer :thumbup: I'm going to replace the spark plugs tomorrow, top up with fresh fuel and I'll check the choke as well, if I still have no luck then I'll take you up on your offer :thumbright:
where next?
How do I go about cleaning the choke plungers?
1. Remove your fuel tank.
2. It will be a bit easier if you remove your airbox aswell but not essential.
3. Trace your choke cables to where it enters each carburetor body.
4. Remove each cable by unscrewing the plastic nut that holds it in. NOTE. The plastic nut is not very strong and is VERY expensive so take your time.
5. Spray some lube into each cable end and work the lever a few times until you are happy that it moves freely.
6. Spray some lube into the hole in the choke body to flush out any dirt or corrosion.
7. Refit the cables. I find it harder to put a cable in rather than taking one out so again, take your time and be careful.
Discussion Starter · #16 ·
Thanks for all the replies.
I stripped it this morning checked the carbs etc and realised the rear choke was stuck completetly on and doesn't slide... I eventually got it freed up, quick rub of wet n dry and some lube now the bike runs like a dream, idles properly, choke works properly and runs better.. only thing I find is when I rev it the revs drop to about 2,000 rpm then drop to idle a bit slower, is this normal?
Going to get some fresh fuel, redex and go for a nice long ride :thumbup:
I will be signing up for forum membership when I get paid next friday :D
Thanks again!
Great news:D
I`d run it with some shell petrol for a while as its high in cleaning adative, watch that choke for sticking again, I know some on here have totally dumped their chokes [see the search engine under africa twin]
When you get back from your long ride with the engine running turn the bars full lock left and right to make sure the choke cables not cutting in, bloody dangerous when engine hot and trying to do a "U" turn as the bike stalls and over you go:confused: dont ask me how I found this out:eek:.
sounds like the bikes not been used regularly SHAME ON YOU LAST OWNER:toothy1:
where next?
Great news that your bike is running better. You might try lubing your throttle cables to see whether the revs return to idle a bit sharper. There is a tiny hole in the curved tube where the cables exit the twist grip. You can get a straw from a lube spray can into this hole. Spray lube and work throttle a few times.
Discussion Starter · #20 ·
Right, well I covered a happy 320km on the AT today... handles well, rides smooth and generally good fun and made me remember how fun biking is going places and seeing things.
Then the ****ing thing broke down on me!
Now I've lost all electrics, doesn't appear to be charging, so I'm assuming this is the reg/rec??? I managed to bump start it with all lights etc off but it only got about a mile down the road before it cut out again... any ideas?
p.s the throttle is definetly okay as I've just stripped, lubed it and removed that crappy white plastic thing.
Here's a pic when it was running good and all was happy! Annoyingly my Samsung 12mp camera seems to have broken also and the image quality is stupidly terrible compared to usual!
Also... under braking with the front brake when slowing down under 30 the bike seems to bounce up and down almost?? like the wheel turns into a square! I'm going to change the brake pads but any ideas what else this could be?
Really like the AT, but still wishing I bought a 950 ADV or a newer less problemous AT :rolleyes: if I can get this thing reliable then I'll be pretty happy with it!
1 - 20 of 57 Posts
