Split the cases on 97 XRV750 but now during assembly the rear cylinder cam shaft sprocket timing marks slightly off...could it be off one tooth on lower sprocket, any suggestions? As you can see in attached photo the left side horizontal mark is about a half or quarter tooth below the right horizontal mark...could it be the timing chain is off one tooth on the lower sprocket...?
See attached also the TDC mark ...
