1 - 16 of 16 Posts
Wing Commander
Just fitted one from M&P.
Used the Givi top box mount as the base.
Wing Commander
£40, well £39.99. But it is very bright.
I'm always seeing cars with one brake/tail light not working and I kept thinking that if mine went I'd have no light at all so a spare would be good. By fitting it to the top box rack it is also higher, which will be handy in traffic.
http://www.mandp.co.uk/productInfo.aspx?catRef=500627
Like that a lot.....think i will have to purchase.
Be safe be seen!!!
Was it easy enough to wire in?
Wing Commander
I just cut in to the existing rear light cable. It comes with instructions showing which wire to join but you need the @wiring diagram to now which is which. If I were doing it again I'd buy some of the those clamp-on wire joiners rather than cut into the cable, but plenty of insulation tape has done the trick.
Is it just a tail light or does it come on with the brake, or both?
Wing Commander
Both.
Gelände Straße
Thats the cool thing yeah...you can put it pretty much wherever you want!
Shame you can't double up on the LED strips and have one each side on the panniers! Can also set them to flash as sort of makeshift Hazard lights too.
Hmmmm....tempting 8)
Still loving that new Helmet Mav? tempted by one of them too, my Roof is just too damn noisy and dreadful in the winter.
skeptical old git
I bet all the "transmitter bulbs" use the same frequency, so you could run two one the same bike.
Mind you, if you were next to another bike with one in traffic it could cause some "amusing" effects...
(like the cordless keyboard user in the next door office using "my" cordless mouse frequency; thankfully she didn't type "/bin/rm -rf /"... but I do know at least one of her passwords now :twisted: )
Need Constant Supervision
Mate so far so good and enjoying it much more than my system V or AGV I had before that. I might note that because of the sharp angle of the visor your vision does seem a bit strange untill you get used to it. It's like your'e being crossed eyed if that would explain the feeling.
But after day two it was snug and very comfy with enough airflow to ride in this heat without needing to open the visor at all. This being the darkish visor is of course a treat since I don't have to wear sunnies which is sometimes a PIA.
It is still early days to give a proper verdict but for £89 what have you got to lose....well except the £89 :lol:
Gelände Straße
My mate said exactly the same thing about his Arai Tour X after he first got it...so even the more expensive lids have the same little quirks.
Goddamnit I'm bleeding myself dry with this new bike! Toys toys and more toys! Bring 'em on! :wink:
1 - 16 of 16 Posts
