Hi all, my Slr650 is now up and running, it mainly needed cosmetic help with being a barn find, so fresh paint on the frame and engine, one thing i don't like are the wheels, can i fit the FMX standard wheels?, new spacers are no probs as i have a little lathe, also can the charcoal filter be removed.
Cheers in advance
Chris
Stone Crazy
charcoal filter ? , is that the filter thingie that has pipes running from the exhaust ports back to the intake , if so take it off and block the ports and pipes , all it does is inject some fresh air in the exhaust port make the emissions seem cleaner , as for wheels i dont know
You can buy blanking plates for where the pipes go onto the cylinder head or you can cut the pipes off and weld over the holes as i did
This is the side that goes onto the cylinder head
