21 - 33 of 33 Posts
Ha, feeling the same way about self isolation. So long as there is plenty of tea the AT my rebuild should come along in leaps and bounds
Sent from my SM-G973F using Tapatalk
Discussion Starter #23
Had a couple of hours at it today, finding the odd mistake that i need to correct such as putting the damper in the wrong way so the reservoir was at the rear rather than the front as it should be. Got a bunch of stuff back from the spray shop so have everything i need now except the body work, some parts probably should be white rather than black but ill live with that
164513
164514
164515
. Pleased i bought new bolts as they really finish it off.
Commuter Extraordinaire
Enjoying this thread :) Keep the progress reports coming.
I guess you had the splined final drive shaft renewed.... where did you get the replacement from - I ask as I believe they're no longer available from Honda?
Discussion Starter #26
Yes I did but not sure of the source, I used a guy called Martin form Martins Motorcycles based in Reading. He came highly recommended and uses parts he trusts (where he couldn't get Honda originals) give hime a call 07786564507.
Rugged Roads have countershafts in stock, I also got one from MSP Europe
Discussion Starter #28
Well working at home certainly allows me to make some progress and keep sane at the same time!! 20 minutes here and there makes a huge difference. Struggling to work out where the 'alternator' (can't remember the correct name of that box) sits
Discussion Starter #29
So i think ill be ready to fire her up by the weekend, just missing the cable that connects the neutral sensor and the oil pressure sensor (i think) to the wiring loom. Cant find one but will search eBay later.
164538
(y) Coming along nicely.
Unless you've got other plans for those headers (or getting a new after market system), can I suggest ceramic coating. Looks a treat for many many years (7 years so far on my AT). The polished look gives way to a satin finish after a year or so but, if you're keen, can easily be returned to the polished look.
Taken in Jan 2013
Discussion Starter #31
Taken in Jan 2013
Looks great, thanks for the suggestion
Taken in Jan 2013
Looks great. A local chap here in NZ suggested he could do this for my rebuild - I just finished stripping everything when the lockdown began. I'm inspired now, it looks fantastic, will definitely take him up up on the offer.
21 - 33 of 33 Posts
