121 - 140 of 210 Posts
Discussion Starter #129
Just had a new batch made and have 5 sets available in stock, I can now get the rear brackets made with 3 or 4 days if required.
Fitted on a RD07a.
Fork pulled out to max. possible length of brake lines. Gives about +4 cm.
You must extend the side stand. I had a +4 cm side stand extention before but with the slugs it is not enough. Better would be +6 cm or so but I´m still working on it.
Hm, you didn't get to use the full length of the extender before the brake lines maxed out? Is there a difference between the RD07 and RD07A in the fork setup/parts? My RD07 could accomodate the full length of the extender without stretching the brake lines all the way.
Maybe it's because of the Wirth fork springs , these are much harder than the original and push the fork apart more.
Don't think so, I had my bike on a lift and maxed out the fork travel when I installed the slugs to make sure that I wouldn't end up ripping the brake lines off in case of some air time ;)
