Africa Twin RD04 XRV750 - Engine Restriction Details
It would appear that the restriction modifications can be ascertained on engine number alone, but only on Austrian and German models. Bikes for the Swiss market were also restricted but their engine numbers are in sequence with the full power models, just to make things difficult.
Also, the Honda Area (Market) Codes are my best guess. Again, if you know better then let me know.
Production years 1990 - XRV750L, 1991 - XRV750M and 1992 - XRV750N, RD04 750cc.
Full Power models for markets B (Belgium), E (England), F/YB (France), G (Germany), H (Holland), It (Italy), ND (Netherlands) and SP (Spain).
Full Power model produced for market AR (Austria) in 1990 only.
Restricted Power models for markets AR (Austria, 1991 and 1992), G/50P (Germany) and SW (Switzerland).
All models have the same CDI unit, the only changes were to the camshafts and the Inlet Rubbers. There are also carburettor changes to the restricted market models.
I will start by listing the standard part numbers -
Camshafts, Part Nos, Front: 14110-MV1-000, Rear: 14120-MV1-000
Inlet Rubbers, Part No: 16211-MN8-750
CDI Unit, Part No: 30410-MV1-003
Carburettors, Part Nos: Front/Right - 16101-MV1-630, Left/Rear - 16102-MV1-630
Main Jet Front/Right: #118, Part No: 99101-393-1180
Main Jet Left/Rear: #122, Part No: 99101-393-1220
Slow Jet: #42, Part No: 99103-437-0420
Front/Right Needle Set, Part No: 16151-MM9-621
Left/Rear Needle Set, Part No: 16151-MV1-700
Front/Right Holder, Needle Jet, Part No: 16165-MF5-671
Left/Rear Holder, Needle Jet, Part No: 16165-MV1-630
Plate Set, Valve; Part No: 16050-MS9-004
Piston Comp, Vacuum; Part No: 16112-MB6-881
Restricted models.
Market - Austria (Honda Area Code "AR"). Note: for years 1991 and 1992 only, NOT for 1990.
Restriction on camshaft only. Carburettors changed for 1991 and 1992.
Engine Nos: RD04E-5000001 to 5000329 for 1991 and
Engine Nos: RD04E-5100001 to 5100346 for 1992
Camshaft Part Nos, Front: 14110-MS8-000 and Rear: 14120-MS8-000
Carburettor Part Nos: Right/Front - 16101-MV1-880, Left/Rear - 16102-MV1-880
Changes to individual components are -
Main Jet Front/Right: #120, Part No: 99101-393-1200
Slow Jet: #38, Part No: 99103-MT2-0380
Front/Right Needle Set, Part No: 16131-MS8-004
Left/Rear Needle Set, Part No: 16151-MS8-681
Left/Rear Holder, Needle Jet, Part No: 16165-MF5-671
Piston Comp, Vacuum; Part No: 16112-MN8-752
Market - Germany (Honda Area Code "G/50P")
Restriction on inlet rubbers only.
Engine Nos: RD04E-3000001 to 3002245 for 1990,
Engine Nos: RD04E-3100001 to 3101536 for 1991 and
Engine Nos: RD04E-3200001 to 3201605 for 1992
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16211-MS9-710
Market - Switzerland (Honda Area Code "SW")
Unlike the Austrian and German models, Swiss bikes CANNOT be determined from Engine Number.
Restriction on camshaft AND inlet rubbers. There are carburettor changes also.
Engine Nos: RD04E-2000040 to 2006085 for 1990,
Engine Nos: RD04E-2100022 to 2105791 for 1991 and
Engine Nos: RD04E-2200010 to 2202882 for 1992
Camshaft Part Nos, Front: 14110-KW0-000 and Rear: 14120-KW0-000
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16211-MV1-640
Carburettor Part Nos: Right/Front - 16101-MV1-640, Left/Rear - 16102-MV1-640 for 1990 only.
Carburettor Part Nos: Right/Front - 16101-MV1-860, Left/Rear - 16102-MV1-860 for 1991 and 1992.
Slow Jet: #38, Part No: 99103-437-0380 for 1990 only.
Slow Jet: #38, Part No: 99103-MT2-0380 for 1991 and 1992.
Right/Front Needle Set, Part No: 16131-MS8-681
Left/Rear Needle Set, Part No: 16151-MV1-640 for 1990 only.
Left/Rear Needle Set, Part No: 16151-MV1-860 for 1991 and 1992.
Plate Set, Valve; Part No: 16050-MK7-771
Thanks for the posting. Ive just started doing the sums to refirbish my old RD04 and if the info can get its power up, thats heaps better. But can I check, as you have listed
Quote: All models have the same CDI unit, the only changes were to the camshafts and the Inlet Rubbers. There are also carburettor changes to the restricted market models.
Does that mean that I will need to change to the below parts to de-restrict it?
Inlet rubbers are ok, but abit concern that the lift of the cams may cause the valve to crash onto the piston crown. Do you know if the derestricted cams are longer duration ones of high lift ones? any problems encountered. Thanks so much
Good post! Do you know anything about restrictions to bikes for the Japanese market? I have a 1991 RD04 from Japan.
Thanks.
Hi, thanks for replying. I have the frame and engine numbers.
Frame - RD04-10000XX
Engine - RD04E-10000XX
Apart from that, nothing. I bought the bike in Moscow and it was imported from Japan.
Thanks.
Heya,
Has anyone priced up, even ball park, the cost of derestricting an AT? It's gotta be at last 300 quid no? to gain 10% more horses?
So many mods, so little money :(
Hello,
Can anyone confirm that the following chassis no. is restricted to 50 ps: RD043100877?
As far as I can tell it should be an M, G(50ps) model, and therefore restricted by inlet rubbers only. Presumably I would have to re-jet the carbs, if I change the insulators?
While the question above is old, to answer it, I guess it depends greatly on your model, and how it is restricted. If it is simply a question of re-jetting the carbs and changing (or boring out) the carb insulators, it shouldnt cost more than 100gbp, possibly quite a bit less.
I have an unrestricted RD04 that had damaged choke tubes, and i purchased a set of carbs off Hamart that turned out to be restricted ones. I am in the process of swapping over all the bits from my original carbs to the austrian carb bodies. i have noticed that both emulsion tubes (needle jet holders) have 10 holes in both sets of carbs? is this correct. I see people talking about the rear E type should only have 6 holes, and the part numbers for the two e tubes are different. Will i be fine with the 16165-MF5-671 (10 hole) e tube in both carbs?
