1 - 2 of 2 Posts
Administrator
Africa Twin RD07 XRV750 - Engine Restriction Details
Because this post would have ended up being very long, I have separated the RD07 and RD07a into different posts.
There were a number of changes from year to year, so I will present the information for each year of production and provide as much detail as available to me.
Production years 1993 - XRV750P, 1994 - XRV750R and 1995 - XRV750S, RD07 750cc.
It would appear that the restriction modifications can be ascertained on engine number alone, but only on Austrian and German models. Bikes for the Swiss market were also restricted but their engine numbers are in sequence with the full power models, just to make things difficult.
Also, the Honda Area (Market) Codes are my best guess. Again, if you know better then let me know.
The situation is not as clear cut as with the earlier models, but bear with me and I'll try and make it as clear as possible.
I will start be listing the standard part numbers -
Camshafts, Part Nos, Front: 14110-MV1-000, Rear: 14120-MV1-000
Inlet Rubbers, Part No: 16211-MY1-000
Carburettors, Part Nos: Front/Right - 16101-MY1-000, Left/Rear - 16102-MY1-000
Individual carburettor components -
Main Jet Right/Front: #118, Part No: 99101-393-1180
Main Jet Left/Rear: #120, Part No: 99101-393-1200
Slow Jet: #40, Part No: 99103-MT2-0400
Right/Front Needle Set, Part No: 16131-MY1-700
Left/Rear Needle Set, Part No: 16151-MY1-640
Holder, Needle Jet; Part No: 16165-KAF-670
Plate Set, Valve; Part No: 16037-MW0-600
Spring, Comp. Coil; Part No: 16050-MY1-000
Piston Comp, Vacuum; Part No: 16111-MY1-000
CDI Unit, Part No: 30410-MV1-003 - this is standard across all markets for the years shown.
Full Power Models for B (Belgium), E (England), F (France), G (Germany), H (Holland), IT (Italy), ND (Netherlands) and SP (Spain).
Restricted Models for AR (Austria), G/50P (Germany) and SW (Switzerland).
Restricted models.
Market - Austria (Honda Area Code "AR").
Restriction on camshaft and inlet rubbers, different carburettors.
Engine Nos: RD04E-5200001 to 5200531 for 1993
Engine Nos: RD04E-5300001 to 5300552 for 1994 and
Engine Nos: RD04E-5400001 to 5400302 for 1995
Camshaft Part Nos, Front: 14110-KW0-000 and Rear: 14120-KW0-000
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MY1-660
Carburettors, Part Nos: Front/Right - 16101-MY1-660, Left/Rear - 16102-MY1-660
Changes appear to be to the Slow Jet and Front/Right Needle Set -
Slow Jet #38, Part No: 99103-MT2-0380
Right/Front Needle Set, Part No: 16131-MY1-000
Market - Germany (Honda Area Code "G/50P")
Restriction on inlet rubbers only.
Engine Nos: RD04E-3300001 to 3301723 for 1993
Engine Nos: RD04E-3400001 to 3401750 for 1994 and
Engine Nos: RD04E-3500001 to 3500910 for 1995
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MY1-780
No changes to carburettors.
Market - Switzerland (Honda Area Code "SW")
Unlike the Austrian and German models, Swiss bikes CANNOT be determined from Engine Number.
Restriction on camshaft AND inlet rubbers.
Engine Nos: RD04E-2300029 to 2305144 for 1993,
Engine Nos: RD04E-2400106 to 2404970 for 1994 and
Engine Nos: RD04E-2501580 to 2502721 for 1995
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MY1-640
Carburettors, Part Nos: Right/Front - 16101-MY1-640, Left/Rear - 16102-MY1-640
1 - 2 of 2 Posts
