Administrator
Africa Twin RD07a XRV750 - Engine Restriction Details
There were a number of changes from year to year, so I will present the information for each year of production and provide as much detail as available to me.
Production years 1996 - XRV750T, 1997 - XRV750V, 1998 - XRV750W, 1999 - XRV750X and 2000 - XRV750Y, RD07a 750cc.
It would appear that 2000 model year bikes were available up to 2003.
It would appear that the restriction modifications can be ascertained on engine number alone, but only on Austrian and German models. Bikes for the Swiss market were also restricted but their engine numbers are in sequence with the full power models, just to make things difficult.
Also, the Honda Area (Market) Codes are my best guess. Again, if you know better then let me know.
The situation is not as clear cut as with the earlier models, but bear with me and I'll try and make it as clear as possible.
I will start be listing the standard part numbers -
Camshafts, Part Nos, Front: 14110-MV1-000, Rear: 14120-MV1-000
Inlet Rubbers, Part Nos: 16211-MY1-000
Carburettors, Part Nos: RightFront - 16101-MAY-620, Left/Rear - 16102-MAY-620
Individual carburettor components -
Main Jet Right/Front: #115, Part No: 99101-GHB-1150
Main Jet Left/Rear: #115, Part No: 99101-GHB-1150
Slow Jet: #40, Part No: 99103-MT2-0400
Right/Front Needle Set, Part No: 16012-MAY-620
Left/Rear Needle Set, Part No: 16027-MAY-620
Holder, Needle Jet, Part No: 16165-MAY-620
Plate Set, Valve; Part No: 16037-MZ2-E00
Spring, Comp. Coil; Part No: 16050-MY1-000
Piston Comp, Vacuum; Part No: 16111-MY1-000
CDI Unit (1996 to 2000), Part No: 30410-MAY-621 - changes according to market for years shown.
Full Power Models for E (England), ED (?), F (France), G (Germany), H (Holland) and ND (Netherlands).
Models for H (Holland) NOT produced in 1996 or 2000.
No model for ND (Netherlands) in 2000.
Restricted Models for AR (Austria), G/50P (Germany) and SW (Switzerland).
Restricted models.
Market - Austria (Honda Area Code "AR").
Restriction on camshaft, CDI Unit AND inlet rubbers. Also changes to carburettors.
Engine Nos: RD04E-5500006 to 5500426 for 1996,
Engine Nos: RD04E-5600006 to 5600340 for 1997,
Engine Nos: From RD04E-5700001 for 1998,
Engine Nos: From RD04E-5800001 for 1999 and
Engine Nos: From RD04E-5810001 for 2000.
Camshaft Part Nos, Front: 14110-KW0-000 and Rear: 14120-KW0-000
CDI Unit, Part No: 30410-MV1-003
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MY1-660
Carburettors, Part Nos: Front/Right - 16101-MY1-660, Left/Rear - 16102-MY1-660 for 1996 only.
Changes to individual components for 1996 only are -
Main Jet Right/Front: #118, Part No: 99101-393-1180
Main Jet Left/Rear: #120, Part No: 99101-393-1200
Slow Jet: #38, Part No: 99103-MT2-0380
Right/Front Needle Set, Part No: 16131-MY1-000
Left/Rear Needle Set, Part No: 16151-MY1-640
Holder, Needle Jet, Part No: 16165-KAF-670
Plate Set, Valve; Part No: 16037-MW0-600
Carburettors, Part Nos: Front/Right - 16101-MAY-840, Left/Rear - 16102-MAY-840 for 1997 to 2000.
Changes to individual components for 1997 to 2000 are -
Right/Front Needle Set, Part No: 16012-MAY-650
Left/Rear Needle Set, Part No: 16027-MAY-650
Holder, Needle Jet, Part No: 16165-MAY-000
Market - Germany (Honda Area Code "G/50P").
Restriction on inlet rubbers only.
Engine Nos: RD04E-3600001 to 3600850 for 1996,
Engine Nos: RD04E-3700001 to 3700580 for 1997,
Engine Nos: From RD04E-3800001 for 1998,
Engine Nos: From RD04E-3900001 for 1999 and
Engine Nos: From RD04E-3910001 for 2000.
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MAY-660
No changes to caburettors on these models.
Market - Switzerland (Honda Area Code "SW").
Unlike the Austrian and German models, Swiss bikes CANNOT be determined from Engine Number.
Restriction on camshaft, CDI Unit AND inlet rubbers. There are also carburettor changes to these models.
Engine Nos: RD04E-2600040 to 2601633 for 1996,
Engine Nos: RD04E-2701805 to 2702409 for 1997,
Engine Nos: From RD04E-2800001 for 1998,
Engine Nos: From RD04E-2900001 for 1999 and
Engine Nos: From RD04E-2910001 for 2000.
Inlet Rubbers (called "Insulator, Carburetor" by Honda), Part No: 16210-MY1-640
Carburettors, Part Nos: Front/Right - 16101-MY1-640, Left/Rear - 16102-MY1-640 for 1996 only.
Carburettors, Part Nos: Front/Right - 16101-MAY-650, Left/Rear - 16102-MAY-650 for 1997 to 2000.
Changes to individual components are -
Right/Front Needle Set, Part No: 16131-MY1-000 for 1996 only.
Right/Front Needle Set, Part No: 16012-MAY-650 for 1997 to 2000.
Left/Rear Needle Set, Part No: 16151-MY1-640 for 1996 only.
Left/Rear Needle Set, Part No: 16027-MAY-650 for 1997 to 2000.
Plate Set, Valve; Part No: 16037-MW0-600 for 1996 only, standard parts for 1997 to 2000.
Hi,
Are all Swiss machines restricted (2002) and if so is it purely emmisions or power output or both and is there anything that can be done as a quick fix?
Administrator
Hi,
Sorry, but I don't believe that there is a quick fix - not with changes to the Camshafts, CDI Units, Inlet Rubbers and Carb internals.
I think that these changes were for both emissions and power output. As my note says the Swiss market models cannot be determined from Engine / Frame numbers alone - the individual parts need checking. One quick check is the CDI as the part number is usually printed on it somewhere.
The XRV750 were produced for the following markets: (Working links for each model)
RD04: 1990 - 1992
RD07: 1993 - 1995
RD07a: 1996 - 2000
1990 AUSTRIA
1990 BELGIUM
1990 ENGLAND
1990 FRANCE / YB
1990 GERMANY
1990 GERMANY / 50P
1990 ITALY
1990 NETHERLANDS
1990 NORTHERN EUROPE
1990 SPAIN
1990 SWITZERLAND
1991 AUSTRIA
1991 BELGIUM
1991 ENGLAND
1991 FRANCE / YB
1991 GERMANY
1991 GERMANY / 50P
1991 ITALY
1991 NETHERLANDS
1991 NORTHERN EUROPE
1991 SPAIN
1991 SWITZERLAND
1992 AUSTRIA
1992 BELGIUM
1992 ENGLAND
1992 FRANCE / YB
1992 GERMANY
1992 GERMANY / 50P
1992 ITALY
1992 NETHERLANDS
1992 NORTHERN EUROPE
1992 SPAIN
1992 SWITZERLAND
1993 AUSTRIA
1993 BELGIUM
1993 ENGLAND
1993 FRANCE
1993 GERMANY
1993 GERMANY / 50P
1993 ITALY
1993 NETHERLANDS
1993 NORTHERN EUROPE
1993 SPAIN
1993 SWITZERLAND
1994 AUSTRIA
1994 BELGIUM
1994 ENGLAND
1994 FRANCE
1994 GERMANY
1994 GERMANY / 50P
1994 ITALY
1994 NETHERLANDS
1994 NORTHERN EUROPE
1994 SPAIN
1994 SWITZERLAND
1995 AUSTRIA
1995 BELGIUM
1995 ENGLAND
1995 FRANCE
1995 GERMANY
1995 GERMANY 50P
1995 ITALY
1995 NETHERLANDS
1995 NORTHERN EUROPE
1995 SPAIN
1995 SWITZERLAND
1996 AUSTRIA
1996 ENGLAND
1996 EUROPEAN DIRECT SALES
1996 FRANCE
1996 GERMANY
1996 GERMANY / 50P
1996 NORTHERN EUROPE
1996 SWITZERLAND
1997 AUSTRIA
1997 ENGLAND
1997 EUROPEAN DIRECT SALES
1997 FRANCE
1997 GERMANY
1997 GERMANY / 50P
1997 NETHERLANDS
1997 NORTHERN EUROPE
1997 SWITZERLAND
1998 AUSTRIA
1998 ENGLAND
1998 EUROPEAN DIRECT SALES
1998 FRANCE
1998 GERMANY
1998 GERMANY / 50P
1998 NETHERLANDS
1998 NORTHERN EUROPE
1998 SWITZERLAND
1999 AUSTRIA
1999 ENGLAND
1999 EUROPEAN DIRECT SALES
1999 FRANCE
1999 GERMANY
1999 GERMANY / 50P
1999 NETHERLANDS
1999 NORTHERN EUROPE
1999 SWITZERLAND
2000 AUSTRIA
2000 ENGLAND
2000 EUROPEAN DIRECT SALES
2000 FRANCE
2000 GERMANY
2000 GERMANY / 50P
2000 SWITZERLAND
That's interesting information. I have a bike I recently purchased from Germany. I have all the original log book information to confirm one owner from Germany, but the engine number starts RD04-280....... which according to your list is from Switzerland.
Just to confuse it even more, when ordering a new speedo for it at my Honda dealer, if you put the frame number into Hondas system, it comes up as a French model!
It is an RD07a from 1998.
I have the mph speedo now and just need to fit it, but would be interested in any comments you may have on the bike?
