1 - 2 of 2 Posts
I made this after seeing a thing on google from the USA called a pack a jack but couldnt find them in the uk,the idea is you can lift your back tyre off the ground by about 1 inch so you can spin the rear wheel to wipe the chain down and re lube,i made it for touring when i had a street tripe and it works great at home too for cleaning the rear wheel and it only takes seconds to fit,it also weighs next to nothing as its made out of alloy angle,i am off to make one for the transalp when i can drop on some more alloy angle,to use you put one end on the floor and the other end on a small bobbin or axle nut,at this point the lift will be bent or open,then push the lift closed with your foot so it locks straight and lifts the wheel off the ground,i dare say if you google pack a jack bike lift the vidio will still be on.
All the good ideas are simple ones. Got tons of ally angle at work. Might take some measurements and make one up. Thanks.
Nick.
1 - 2 of 2 Posts
