Is this a possible leakage? Have not blown in the box to test if there is a leakage.
What kind of glue to use?
Thanks!
Had some trouble to find it here i Sweden. Then I found out that it is sold under the name "Plastic Padding Repair Extreme" in Sweden.
Will fix the leak as soon as possible.
Space Emperor
I had the same problem. I scratched up the surface and used some copper silicone gasket I had laying around ... seems to hold well, but should probably see if I can find some Plastic Padding Repair Extreme next time I'm in DK ...
