HI
IS there someone in this forum that maybe can give me some advise on how to clean my anti freeze reservoir so that i can clearly see the level of coolant still left in the container. i have to take the side panel off to get see it.
Stone Crazy
Well i did my daughters screen washer reservoir for her car with a old paint brush cut the handle off and attached to some stiff wire , a then used fairy liquid and hot water to clean it , it maybe that you can bleach the reservoir ,
Thanks for the response also thought of bleach will give it a try first and then try the brush. The hole at the top is not very big will have to use a small brush to get inside the container.
Stone Crazy
maybe an old toothbrush would do the trick
A metal/wire rod in an electric drill with the end of the wire folded over some strips of cloth. Fire the drill up and centrefugal force spins the cloth out and scours the gunge off the inside of the container. Adjust to suit as you use it.
