That damn bead!
At long last managed to get my tyres at home from work and decided to give this tyre fitting malarky a bash.
Front tyre came off pretty easy and needed to grab the old impact tool to get the rusty screws out.
As you can see they have not been out for a while :?
No broken studs, bolts etc and copper greased everthing with the fitting again
The front tyre bead if there was one was no hassle at all and managed to swap the tyres and tubes in about 40 minutes (Yes I caught the tube when refitting the new wheel and buggered it up
I was about to take out the caliper pins but could not work out if they screw or just push out ? So left them as is although did spray some brake cleaner around the caliper pistons to clean them a bit. The do seem to work regardless of the dirt around them.
Something worth mentioning probably is remember to check the rotation of the tyre before fitting it back onto the rim
You can barely make out the arrow in the left top of the above picture.
Again in the following on 12 o'clock you should check the arrow.
It was recommended to me as precaution to rather fit new tubes and as mentioned good thing ordered them as I stuff the brand new one up the firts time around.
Wheel torque according to the little handbook is around 68nm
And the small nuts with the copper grease that looks like rust should be around 12nm.
Even though with more than 13k miles on the front it seems ok for another while but note the way the left hand blocks are worn more than the right
Not bad for a bridgestone and touch wood never left the road under me
NOw I know you guys are probably sitting there in great anticipation awaiting my exciting news about the rear so let's start with this...
Yes that's correct my side stand broke off from the Tenere as the bead broke on one side of the rear tyre. I have been struggling the last 2 hours to get the other side of the bead broken and no luck. Have soaked the m*&^fu$£ker in oil and wd40 and having some tea. So another tip make sure the side stand is in good nick and not 20 years old.
Only problem now is I do not have another side stand to break :shock: and thinking unless really really really necessary stuck next to the road in africa somewhere will I attemt to change the bloody rear tyre. For the sake of £10-15 it can rather be done by someone with the right tools.
Watch this space..... :roll:
