Hi I am new here so be gentle ha ha
I recently bought an XRV750 RD07 1993 as a non runner.
I replaced the 30 amp fuse and voltage rec and bike was running pretty quickly.
the bike was surging and spluttering mid range and was hard to ride due to power was inconsistent.
so stripped carbs and done rebuild but the previous owner had put in the emulsion tubes with thread seal??? and the mixture screws were snapped off, so it was a mission to get rebuild done due to obsolete part.
replaced the following diaphragms, emulsion tubes and the usual rebuild kit on carb, spark plugs all replaced, clean fuel, fuel filter ,air filter and two coils to front cylinder because the leads were too short and new voltage rec unit and new battery.
bike won't start but mixture screw set to two and a half turns out as starting point. bike just back fires very loudly.
stripped carbs three times now and even put a different set on and same issue.
I was thinking that maybe fuel pump stuck on and over fuelling carbs but nothing coming out of overflow tubes.
looked at fuel pump and the wire snapped to the contact on removal and now can't get until shops open.
Anyone had similar issues???
also sorry to go on but I have 90psi on compression both cylinders just turning over on starter motor book say 150 to 200 at 4000rpm but can't run so can't check any further.
thanks for reading the long explanation
