Can anyone give me a clue please? mechanic says my 04 is running lean on the front plug on one pot, plug is very white. talking about up-jetting the carb? My skills are nill so I will pass the thread on so he can see it.
Thanks in advance
Ivan
Wing Commander
RD04 or 07.
On RD04, adjustment screw require the tank off - or at least raised.
There is a screw left and right cannot remember which side is front and which is rear but it will be obvious. You Screw it right in and then unscrew it by a set number of turns normally. But if you know one is specifically out then I guess you could just unscrew that a tiny bit more and see how it goes. Once you have done the adjustment you have to balance the carbs again.
Makes a big difference.
Administrator
I wouldn't think the jetting would be out.... unless the carbs have been "fiddled with". Are all 4 plugs the correct type? do you have any air leaks between carb and cylinder-head (manky rubber?) causing a weak mixture? Is the float level correct? Is the needle clip set at the correct notch? (not sure if this is adjustable on the AT)
As Chris says, cartb balance/synchronization can make a big difference to overall running (although the mixture screws affect mainly tickover/slow running, so I'd not expect them to change greatly the plug colour)
RD04 or 07.
Chris, the pilot screws will have neglible difference to mixture & plug colour at anything much above tickover.
Carb balance does nothing for mixture but the bike will run better/nicer with balanced carbs.
IMHO, the plugs often/should come out perfectly white/clean on a modernish engine, or they do on mine anyway.....
Assuming (as Hotbulb says) the carbs haven't been messed with, float heights are correct & no air leaks my suggestion would be sticky choke on the rear (making it run richer).
Phil
Massive split in the front carb diaphram, it sounds so much meatier now and mechanic said on the test ride it rode like a different bike! we shall see if it ever stops raining long enough. all good though, a few quid lighter but got to be done. Thanks for the pointers though, the carb had been played with as the mix screw was right in.:D
