Hi all again, long time no post as the AT had been stood a while
Anybody have any suggestions please??, when starting she runs on one pot and the exhaust pipe get quite hot, if I rev her a bit she pops and gurgles a bit then both cylinders pop into life... could this be the ethanol in the carbs whilst stood ? Think it’s fuel related as it’s fine once warmed up.
Facet pump fitted
New plugs
Carbs balanced
Chokes service and new metal sliders fit
Valve clearance recently done
Any suggestions would be greatly received
Check the voltage at the battery if its low could be effecting the cdi unit I know this happens I had the same problem on a rd03. You could also try redex in fuel.
Charged battery on optimate, it’s full power, think you are right with the redex though, I’ll try that
Thank Ian
Cataclean is another alternative to Redex
Clean up the spade terminals on the front coil if it's the front cylinder playing up. They cop all the weather and go a bit green. Had that a few times in the past.
Welcome to the world of modern gasoline.
How long did the bike "sat"?
I'm betting your pilot jet is clogged. Easy and cheap to replace.
In future drain the float bowls before any stagnant period more than 3 weeks or so.
Space Emperor
I'd suggest the choke if you hadn't fixed that already ... The only other idea I have is to check the main fuse and see if it's about to weld itself dead.
Thanks for all the suggestions, Redec has sorted the starting issue must have had a touch of dirt in there
