1 - 11 of 11 Posts
Any recommendations? Sick of chilly fingertips and thumbs... Don't have the standard hand guards fitted (broke off ages ago lol). My worry about muffs is do I need to put the mirror through a separate hole to the cables etc?
Cheers :)
Muffs are usually designed to accommodate the mirrors.
Unfortunately you will still be cold as I know from experience. Having also used heated grips (ok for the inside of your hand) before I have decided to try heated gloves this year. Bit of a faff getting wired up before riding but they do work.
Don't want to put you off but,
I tried muffs on my TA but found that they made my hands colder.
What seemed to happen was they created a vacuum which sucked cold air in.
Especially through the holes where the cables went in.
I tried them without handguards.
They did work on my old Honda NTV though.
Perhaps the ari eflow was differnet on unfaired bike?
If you are near east anglia I have an old pair you could try out. (sorry just seem you are at Bath!!)
Heated grips and heated gloves, the only way to go, makes it so much more comfortable when it
gets down to single figures :thumbup:
Mines a big red one
I use muffs and heated grips. This allows me to use summer gloves all year round. cable ties around mirror and cable entries stop the draughts.
SOTGATT
+1 They look bad but work so well you won't care.:thumbup:
Muffs with ties will work better if you replace the busted hand guards... at high speed without the guards the wind blast pushes the muffs against/depressing the brake lever just enough to be an annoyance - okay to about 5 degrees celcius. Beyond that to -5 I turn on the heated grips... on longer cold temp trips and quick -20 commutes I'll wear my LI ON Battery gloves - heating element goes up and around each finger tip.
Discussion Starter · #10 ·
Ok, ordered some £20 guards based on
a) I'm always dropping the bike and breaking levers
b) I hear they keep the wind off
If they fix the issue then yay, if not then I'll buy some muff's and put them over the top- should solve the wind/brake lever issue.
Will post back with results.
Cheers guys :)
Mines a big red one
Cheers guys :)
Guards will help, but they won't solve the problem. I've got big guards but still use muffs in the winter.
1 - 11 of 11 Posts
