F
Guest
After reading and starting various threads about improving RD03 brakes I decided to try changing the disc and pads. I'd previously replaced my pads with organic EBC pads and wasn't very impressed. Honda OE front discs do seem to be occasionally available from DSS and the rear is common to several other models in size if not appearance.
I looked at various options from Honda, Braking and Grimeca and decided to give the Grimeca discs a go. Ordered the discs from Bike Torque Racing in Frome who were very helpful but they did take four months to appear from Italy! I was on the verge of giving up...
Goodies
Old disc (not standard)
New Grimeca disc in place
Brembo pads fitted
Almost ready to go
Only took 30mins ish to swap the disc and pads, I'd overhauled the caliper not too long ago so everything came to pieces easily.
Still bedding in but on a short run, in the dry, there's definitely more bite, feel and ultimately retardation. Will report how they perform in the rain and when fully bedded in.
I really need to overhaul the master cylinder and fit a shorter front hose but so far so good.
Costs:
Front disc - £73.73 +VAT
Rear disc - £62.51 +VAT
Brembo carbon front pads - £23.45 +VAT
Brembo sintered rear - £27.36 +VAT
Plus a few quid for new OE disc bolts
I think the discs worked out to being as bit cheaper than the OE ones and at the time I ordered I couldn't see any OE fronts anyway. Really thought I'd just give them a try as an option.
David
Maybe a silly question but why a shorter front hose?
F
Guest
Just because the current one is a bit baggy, you can't see from the pics but it sticks out a fair bit to one side, no big thing really.
If you wanted to get rid I would be interested as I am making some fork extentions and need approx 50mm extra length on my front brake cable.
I would be interested to know how much longer it is than standard!!
Cheers Kitped
F
Guest
Cheers Kitped
If I get around to changing it soon (it's not a high priority) I'll let you know.
