1 - 20 of 28 Posts
Take a peek at the calendar. A run designed for big trail bikes. Your bike will get dirty but hopefully not stuck! Start in Castle Combe. :thumbleft:
How much faster road stuff is there likely to be and what sort of mileage is the route? I quite fancy an outing but only have the CRM in the stable at the moment.
Got a smaller CC machine too.... it'll be warmer than the last time in Feb a couple of years ago...:D
I may come along on the xr if not I'll have to get some tkc's for the gs.
If you all come along on cheats bikes I might as well bring the DRZ! :rolleyes: The idea is for a slower pace on the lanes for bigger machines.
I'll wear my earplugs then :).
I quite fancy a relaxed bimble at a slower pace and, as it's my only bike at the moment, it's that or nothing.
You can borrow my 640 Alan...........
........ as long as you promise to buy it afterwards :D
I shall be on a 950 :thumb:
Discussion Starter #11
No problem Chris. I'm sure with the wealth of skill that you possess you will cope fine.
OK OK OK,Tony:D I'll bring my AT then, and if Ollie wants to come - he will make an additional +1 AT:thumb: only if the forecast is OKish.:D
hedgerow specialist...
hi ,
do you recon this is do able on a Alp650 with tourance fitted,newish rear .
not done too much off road stuff unless you count the odd excursion into the Gravel when the bend get over cooked:rolleyes:.
would love to have a laugh and get dirt- ish, I know the tourance are crap on grass [ induce the splits] but on gravel are so so.
would it be best to drop rear pressure a bit or leave alone?
Datsun fan if you go I could meet up on route around sailsbury somewhere?
Discussion Starter #18
To all with smaller trailies (under 600ccish), I will organise another run out soon. This one is meant to be for biguns as stated. Can't say fairer than that can I? :hitler:
The AT it is then - spend tomorrow taking jerrycans off! :D
1 - 20 of 28 Posts
