Hi I’m having problems starting my 09 700xl the battery is reading ok but the bike won’t start and all I’m getting is a clicking noise from around the fuse side but I’m able to jump the bike of another bike and it will start
Clicking is the starter relay - which is getting enough to juice work but not enough to pass on to the starter.
Check the battery again - if its been left to go go flat and recharged it might seem ok but could be internally damaged. Might be best to invest in a new battery if the old un doesn't check out.
https://www.yuasa.co.uk/info/motorcycle-and-powersport/battery-discharging-charging-characteristics/
https://www.totalmotorcycle.com/maintenance/battery
When a battery reads only 12 volts under the above conditions, it’s almost fully depleted. Actually, if a battery’s resting voltage is only 12.0 to 12.1 it means only 20 to 25% of its useful energy remains. It’s either a goner or it has been deep cycled, and a battery can only be deep-cycled a limited number of times before it is indeed dead.
in my experience the battery should read at least 12.5 volts at rest in order to start
are you sure the battery is charging ok? i had the problem of flat batteries and the problem was not the battery, but a dodgy connection from the alternator to the rectifier, resulting in not quite enough charging volts reaching the battery when i had the heated grips/lights on
see:
https://www.xrv.org.uk/forums/transalp/167437-need-help-voltage-650-a.html
