This is just a grumble and I will feel better when I have finished!!!
Picked up a K&N air filter this morning. About 2pm decided I would fit it. This being the first time I have done any work on the TA since buying it in May. Read the Haynes manual - fairing off, tank off, fit filter, put it all back together. About an hour and a half I thought - including coffee and biccy breaks.
2hours later, 18 bolts/screws, 8 plastic fasteners, and 6 major fairing components later I have got the fairing off. An hour later and 1 bolt and 4 pipes later I get the tank off - course its dark by now. Did the rest by headtorch!! Who designed this bl**dy bike.
Filter goes on doddle- but it is still 8 screws to remove the filter cover. But fairing and tank off in 3hours just to check/change the filter - someone at Honda should be SACKED!!!!! Also just read further in the manual - to check the plugs also involves removing the fairing - FUC*ING H*LL!!!
Of course I got thoroughly pee'd off with the breather pipes at the back of the tank so I cut them. Eventuall got some pipe joint thingy's at carcare and just shoved 'em together - don't give a toss right now if they are joined or not.
Putting it all back together was bit easier - but that 3-piece b*stard stone guard took about half an hour. And do those plastic trim clips really work?
Washed my hands and went straight to the pub. 4 Pints of "Top Totty" and I feel a bit less harassed, but don't even want to look at the TA again.
Tools needed were only 8 and 12mm spanners, 1xallen key, phillips screwdriver, pliers, scissors!! It is just that everything is awkward, hard to get at, needs 4 hands with qaudruple articulated fingers or multiple alignments.
I know it was a first time job and it will be quicker and seem easier next time but that fairing is a genuine PITA and enough to get me seriously considering selling the blood thing!!!
NOT HAPPy!!!
NOT HAPPy!!!
