Just cleaning up the calipers and changing my pads and noticed the center piston on left caliper dosent move and is not seized,
Is this due to the abs and If so how dose it work?
all three pistons should move
the abs system regulates the amount of pressure in the hydraulic line that feeds the caliper
Does it have combined brakes (CBS)?
The rear brake operates the centre piston on one of the front calipers, I'm not sure if abs bikes have this still.
Phil
I noticed that earlier 700 Transalp had two-pot front calipers, and later ones had three-pot front calipers.
Phil
Yeah it's fitted with C - ABS so I assume that the center piston is controlled via the back pedal
