Cheers guys - did they fit straight on?
Well yes and no, if you just unbolt the bar clamps and put the new ones in place then yes they fit straight on, trouble is you find the old bars with all the gubbins still on them get in the way going down the road :lol: .
Best to take all the bits off the old bars first, then have a look at the bottom half of the switch and throttle clamps, you will find there is a small 'pip' that is used for locating on the old bars. You need to file these off first, sliding the throttle grip side on before mounting the bars makes life a bit easier as well.
Don't forget...
Have you ordered new rubber grips 'cos I had to cut the left one off, damm fierce Jap glue they used.
Your old bar end weights will not fit a) nothing to screw them into b) the bars are made of a lot thicker material so the internal diameter is smaller.
The bar clamps go on a specific way up ( should be marked with a small dot to the top ) and the top bolt is torqued down first to 19 foot pounds then the bottom bolt to the same setting.
